New_Age 0 Posted April 7, 2007 Share Posted April 7, 2007 Hi guys, Been awhile . Seems CCleaner isn't removing these Issues. When I tried to open in RegEdit it came with ERROR: Cannot open .APL: Error while opening file. Any Ideas to solve it? Screenshot below. *Total 106 Problems. Windows 7 Ultimate 64-Bit Edition | COOLER MASTER Centurion 590 with 4 120mm Blue LED FANS 1 Regular 120MM FAN and a Custom Window Side Panel | AMD Athlon II x4 2.6GHZ Stock| XIGMATEK HDT-S963 92mm | ASRock A780GXE/128 | G.SKILL 4GB (2 x 2GB) @800MHZ | CF 2 XFX 4850 1GB @GPU940/MEM1005 | 320GB/OS 160GB/Storage HDDs | LG CD/DVD SATA | Rosewill 600W 2 12v Rail@44 | Ccleaner, Defraggler | Malwarebytes', SUPERAnti-Spyware | Avira AntiVir Personal | Google Chrome v3/4, IE8 Link to post Share on other sites
Moderators Andavari 2 Posted April 7, 2007 Moderators Share Posted April 7, 2007 Try Dial-a-fix's Repair Permissions. One big problem is at the very bottom of the list as it looks like CCleaner is detecting it's own CCHelper.ocx ActiveX control registry data. Link to post Share on other sites
New_Age 0 Posted April 7, 2007 Author Share Posted April 7, 2007 Try Dial-a-fix's Repair Permissions. One big problem is at the very bottom of the list as it looks like CCleaner is detecting it's own CCHelper.ocx ActiveX control registry data.Thx but what sections should I be checking before conituning the repair? Windows 7 Ultimate 64-Bit Edition | COOLER MASTER Centurion 590 with 4 120mm Blue LED FANS 1 Regular 120MM FAN and a Custom Window Side Panel | AMD Athlon II x4 2.6GHZ Stock| XIGMATEK HDT-S963 92mm | ASRock A780GXE/128 | G.SKILL 4GB (2 x 2GB) @800MHZ | CF 2 XFX 4850 1GB @GPU940/MEM1005 | 320GB/OS 160GB/Storage HDDs | LG CD/DVD SATA | Rosewill 600W 2 12v Rail@44 | Ccleaner, Defraggler | Malwarebytes', SUPERAnti-Spyware | Avira AntiVir Personal | Google Chrome v3/4, IE8 Link to post Share on other sites
Moderators Andavari 2 Posted April 7, 2007 Moderators Share Posted April 7, 2007 Thx but what sections should I be checking before conituning the repair? Please clarify, I don't understand your question. Are you talking about CCleaner, or Dial-a-fix? Link to post Share on other sites
New_Age 0 Posted April 7, 2007 Author Share Posted April 7, 2007 Sorry, was meaning Dial-A-Fix Windows 7 Ultimate 64-Bit Edition | COOLER MASTER Centurion 590 with 4 120mm Blue LED FANS 1 Regular 120MM FAN and a Custom Window Side Panel | AMD Athlon II x4 2.6GHZ Stock| XIGMATEK HDT-S963 92mm | ASRock A780GXE/128 | G.SKILL 4GB (2 x 2GB) @800MHZ | CF 2 XFX 4850 1GB @GPU940/MEM1005 | 320GB/OS 160GB/Storage HDDs | LG CD/DVD SATA | Rosewill 600W 2 12v Rail@44 | Ccleaner, Defraggler | Malwarebytes', SUPERAnti-Spyware | Avira AntiVir Personal | Google Chrome v3/4, IE8 Link to post Share on other sites
JDPower 0 Posted April 7, 2007 Share Posted April 7, 2007 Sorry, was meaning Dial-A-Fix Not used Dial-a-fix for a while but I think you click the tools button and select 'Repair permissions' from there. Link to post Share on other sites
New_Age 0 Posted April 7, 2007 Author Share Posted April 7, 2007 All done! Thx guys Windows 7 Ultimate 64-Bit Edition | COOLER MASTER Centurion 590 with 4 120mm Blue LED FANS 1 Regular 120MM FAN and a Custom Window Side Panel | AMD Athlon II x4 2.6GHZ Stock| XIGMATEK HDT-S963 92mm | ASRock A780GXE/128 | G.SKILL 4GB (2 x 2GB) @800MHZ | CF 2 XFX 4850 1GB @GPU940/MEM1005 | 320GB/OS 160GB/Storage HDDs | LG CD/DVD SATA | Rosewill 600W 2 12v Rail@44 | Ccleaner, Defraggler | Malwarebytes', SUPERAnti-Spyware | Avira AntiVir Personal | Google Chrome v3/4, IE8 Link to post Share on other sites
