dds Posted December 7, 2006 Share Posted December 7, 2006 Is CCleaner Version v1.35.424 program compatible with Windows XP Professional x64 edition??? dds@skim.com Link to comment Share on other sites More sharing options...
Oliver Posted December 7, 2006 Share Posted December 7, 2006 dds asked: Is CCleaner Version v1.35.424 program compatible with Windows XP Professional x64 edition??? yes it is... Kernel-Execution Implementation 64 to 32 bit internally on the OS side and full 64-bit OS support from the Programs side. The "Issues Scan & Fix" feature should be safe aswell. Anyway backup or better image your data before first-time usage... Oliver Link to comment Share on other sites More sharing options...
dds Posted December 7, 2006 Author Share Posted December 7, 2006 dds asked: yes it is... Kernel-Execution Implementation 64 to 32 bit internally on the OS side and full 64-bit OS support from the Programs side. The "Issues Scan & Fix" feature should be safe aswell. Anyway backup or better image your data before first-time usage... Oliver Thanks Oliver, i'll give that a try Link to comment Share on other sites More sharing options...
