CCleaner Community Forums
papajoe
Flash Player Won't Work
My flash player has stopped working and when I try to access an online video, say YouTube, I get the following message:
Hello, you either have JavaScript turned off or an old version of Macromedia's Flash Player. Click here to get the latest flash player.
I had this problem before, and I found a website that was provided in this forum, I believe, and it permitted me to uninstall and then reinstall Adobe Flashplayer and that fix the problem.
I have tried to find Flash Player by going to the Control Panel, but I can't find it there. I had thought that if I could find it, I would just uninstall and then reload it again as that worked last time.
Any ideas on how I can fix this problem?
Thanks.
Share this post
Link to post
Sorry folks. I just found out how to uninstall it. I have uninstalled it and downloaded a new version and it is now working fine. This is the second time that I have had to do this, and I don't know what the problem is. Perhaps this is something that I will just have to live with.
Thanks.
Share this post
Link to post
Thanks.
Do you use any registry cleaners? Example Regseeker and RegScrubXP found some flash reg. entries as invalid. So if you delete them, that may cause flash not to work proberly.
Share this post
Link to post
You know something, CeeCee, I think that you just hit the nail on the head (if I can be forgiven for using a chliche).
I hadn't thought of that before, but I do use RegSeeker and CCleaner. I had to uninstall and download FlashPlayer again on Friday afternoon, and now that you mentioned it, I now recall that I had used RegSeeker just prior to doing it.
I think that you are right, and I have been unwittingly causing my own troubles.
Thank you very much for drawing my attention to this. At least if it happens again, I'll know what is causing it.
Joe
Ottawa, Canada
Share this post
Link to post
I downloaded the new version this afternoon and scanned with it. Flash Player worked just fine afterwards.
Thanks for nailing this problem for me, CeeCee.
Share this post
Link to post
"My flash player has stopped working and when I try to access an online video, say YouTube, I get the following message:
Hello, you either have JavaScript turned off or an old version of Macromedia's Flash Player. Click here to get the latest flash player. "
I have the same problem and I was allowed to uninstall and reinstall Adobe Flashplayer but it still won't work on Youtube
it works on the other sites that embed the Youtube videos in them though.
I don't think I use registry cleaners
Can anyone think of a solution?
I'm really stumped
Thank you
Share this post
Link to post
Just wanna mention, that flash player bug is fixed on latest RegSeeker (1.52).
RegSeeker is now at 1.55 B)
http://www.hoverdesk.net/freeware.htm
Share this post
Link to post
Which browser are you using?
This is the same message I get when using Firefox with Noscript actively blocking a site with flash content.
If I allow the site then the flash content plays.
Share this post
Link to post
Register a new account
Sign in
