Eldmannen Posted September 9, 2006 Share Posted September 9, 2006 Yes, that is okay and motherboard has integrated graphics chipset, so if you don't play advanced games much, then you don't need buy a graphics card. But you need to buy a sound card and network card. Link to comment Share on other sites More sharing options...
par0x Posted September 11, 2006 Author Share Posted September 11, 2006 would a dvd work aswell or does the motherboard need to support dvd drives.. Link to comment Share on other sites More sharing options...
Eldmannen Posted September 12, 2006 Share Posted September 12, 2006 Yes, a DVD works. Some DVD are SATA (Serial ATA), most are good old fashioned PATA (Parallel ATA). Both should work. DVD works on all computers, the motherboard doesn't need support anything special. DVD burners are cheap nowadays. Link to comment Share on other sites More sharing options...
kobrakommander56 Posted September 12, 2006 Share Posted September 12, 2006 Ha, 7950 gx2, it will last a while.... yeah maybe until DX10 comes out. Insert random C4 joke here. Link to comment Share on other sites More sharing options...
New_Age Posted September 12, 2006 Share Posted September 12, 2006 Wow, I just got done figuring out my total my mt PC that I'll be putting together. A total of $982.85! Not bad but here are my parts... (That's good right?) Case Motherboard CPU Hard Drive Combo Drive LCD Moniter IDE Cable Wireless PCI Adpater Graphics Card Speaker system RAM Sound Card CPU Cooler Windows 7 Ultimate 64-Bit Edition | COOLER MASTER Centurion 590 with 4 120mm Blue LED FANS 1 Regular 120MM FAN and a Custom Window Side Panel | AMD Athlon II x4 2.6GHZ Stock| XIGMATEK HDT-S963 92mm | ASRock A780GXE/128 | G.SKILL 4GB (2 x 2GB) @800MHZ | CF 2 XFX 4850 1GB @GPU940/MEM1005 | 320GB/OS 160GB/Storage HDDs | LG CD/DVD SATA | Rosewill 600W 2 12v Rail@44 | Ccleaner, Defraggler | Malwarebytes', SUPERAnti-Spyware | Avira AntiVir Personal | Google Chrome v3/4, IE8 Link to comment Share on other sites More sharing options...
Eldmannen Posted September 13, 2006 Share Posted September 13, 2006 New_Age, the Pentium 4 sucks. It is built on the crappy Netburst architecture. It provides poor performance, generates massive amount of heat, and needs hell of a cooling, which often results in a noisy computer. You choose a PATA harddisk and PATA IDE cable, instead of go with SATA (Serial ATA). PATA is getting phased out in favor for SATA which provides higher performance and got slimmer cables which reduces clutter and is good for the airflow. Your motherboard is old tech, it doesn't have PCI-Express which pretty much all of todays motherboards got. Your graphics card is AGP. The motherboard NIC is only 10/100, most nowadays are gigabit. The LCD monitor qualifies to TCO '99, latest is TCO '03. It's response time is 8 ms, it is good enough for use application software, but if you do games, you might want to check into one that can handle 2 ms. Pretty cool that the soundcard comes with Audacity, which is open source, go Diamond! Link to comment Share on other sites More sharing options...
New_Age Posted September 13, 2006 Share Posted September 13, 2006 Ok, I'll go back and look at the CPU's and the Motherboard. Plus for a Graphics card. Windows 7 Ultimate 64-Bit Edition | COOLER MASTER Centurion 590 with 4 120mm Blue LED FANS 1 Regular 120MM FAN and a Custom Window Side Panel | AMD Athlon II x4 2.6GHZ Stock| XIGMATEK HDT-S963 92mm | ASRock A780GXE/128 | G.SKILL 4GB (2 x 2GB) @800MHZ | CF 2 XFX 4850 1GB @GPU940/MEM1005 | 320GB/OS 160GB/Storage HDDs | LG CD/DVD SATA | Rosewill 600W 2 12v Rail@44 | Ccleaner, Defraggler | Malwarebytes', SUPERAnti-Spyware | Avira AntiVir Personal | Google Chrome v3/4, IE8 Link to comment Share on other sites More sharing options...
New_Age Posted September 13, 2006 Share Posted September 13, 2006 Ok, changed mostly everything. I'm not into games all that much so... It's total is $807.74 Case Motherboard CPU RAM Sound Card Graphics Card LCD Monitor Hard Drive CD/DVD Drive Windows 7 Ultimate 64-Bit Edition | COOLER MASTER Centurion 590 with 4 120mm Blue LED FANS 1 Regular 120MM FAN and a Custom Window Side Panel | AMD Athlon II x4 2.6GHZ Stock| XIGMATEK HDT-S963 92mm | ASRock A780GXE/128 | G.SKILL 4GB (2 x 2GB) @800MHZ | CF 2 XFX 4850 1GB @GPU940/MEM1005 | 320GB/OS 160GB/Storage HDDs | LG CD/DVD SATA | Rosewill 600W 2 12v Rail@44 | Ccleaner, Defraggler | Malwarebytes', SUPERAnti-Spyware | Avira AntiVir Personal | Google Chrome v3/4, IE8 Link to comment Share on other sites More sharing options...
Eldmannen Posted September 13, 2006 Share Posted September 13, 2006 New_Age Why do buy a new computer? The computer you have in signature is good enough, and by the components you choose, I wouldn't consider it worth to buy a new one, if you're looking to replace your computer. But maybe you just want an additional computer for some reason? The monitor is 8ms, this shouldn't be any problem unless you play games (esp first-person shooters). The motherboard is 100/100 ethernet, this shouldn't be a problem, worth to note is that most motherboards nowadays come with gigabit ethernet. The harddisk is SATA-300, but this one is 8 mb cache, the one you picked before was 16 mb. Also, the link to the CPU points to the motherboard. Link to comment Share on other sites More sharing options...
New_Age Posted September 13, 2006 Share Posted September 13, 2006 Well, with my PC now I'm abit upset. My Case is good but when I put my Motherboard in side it did go in but the Wireless Adpater, Graphics Card didn't seem to go down all the way into the slots which really pissed me off. I just wanna start fresh and all. I'm be giving this computer to my GF so... yeah. Note: I had to cut off the ends of the metal for the Video Card and Wireless adpater to fit in. 2nd note: I went to Newegg and setted up a good deal better then what I got with TigerDirect. I'll post the stuff I'm going to buy soon. Windows 7 Ultimate 64-Bit Edition | COOLER MASTER Centurion 590 with 4 120mm Blue LED FANS 1 Regular 120MM FAN and a Custom Window Side Panel | AMD Athlon II x4 2.6GHZ Stock| XIGMATEK HDT-S963 92mm | ASRock A780GXE/128 | G.SKILL 4GB (2 x 2GB) @800MHZ | CF 2 XFX 4850 1GB @GPU940/MEM1005 | 320GB/OS 160GB/Storage HDDs | LG CD/DVD SATA | Rosewill 600W 2 12v Rail@44 | Ccleaner, Defraggler | Malwarebytes', SUPERAnti-Spyware | Avira AntiVir Personal | Google Chrome v3/4, IE8 Link to comment Share on other sites More sharing options...
New_Age Posted September 13, 2006 Share Posted September 13, 2006 Ok, heres what I got out of Newegg. Case Motherboard CPU RAM Sound Card Graphics Card Hard Drive Speaker System LCD Monitor CD/DVD Combo Drive Windows 7 Ultimate 64-Bit Edition | COOLER MASTER Centurion 590 with 4 120mm Blue LED FANS 1 Regular 120MM FAN and a Custom Window Side Panel | AMD Athlon II x4 2.6GHZ Stock| XIGMATEK HDT-S963 92mm | ASRock A780GXE/128 | G.SKILL 4GB (2 x 2GB) @800MHZ | CF 2 XFX 4850 1GB @GPU940/MEM1005 | 320GB/OS 160GB/Storage HDDs | LG CD/DVD SATA | Rosewill 600W 2 12v Rail@44 | Ccleaner, Defraggler | Malwarebytes', SUPERAnti-Spyware | Avira AntiVir Personal | Google Chrome v3/4, IE8 Link to comment Share on other sites More sharing options...
Eldmannen Posted September 14, 2006 Share Posted September 14, 2006 Some things to note. Just pointing out stuff. The socket for the motherboard and CPU is socket 939. The latest is socket AM2, however I think DDR2 memory is needed for that. The memory is DDR, the latest is DDR2, though it might be more expensive, don't know. The soundcard is an SB Audigy, it is 2 generations old or so, I think. There was Audigy then Audigy 2 then X-Fi. None the less, it probably is a good card. As for the graphics card, I would personally go with a nVidia, because ATI are powerhungry monsters and big heat generators, I think. nVidia probably is too, heh. The graphics card you selected has a fan, most graphics cards today unfortunately have a fan, not all though. Nvidia has better graphics drivers for Linux than ATI. As for the monitor, it is 8ms, shouldn't be a problem though unless you play FPS games. The review on the site you mentioned, said the quality wasn't all that great using an analog connection, so be sure to connect it to the graphics card via DVI. The hard disk has 8 mb cache, WD has models with 16 mb cache too. I am not sure of the price difference or performance difference, just pointing that out. Also Western Digital SE disk is the disk that produces the least noise on the market, and is also one of the best in terms of power consumption. As for the DVD, Lite-On have a good reputation of having cheap drives that are of quality up to par with Plextor. Good choice. Link to comment Share on other sites More sharing options...
New_Age Posted September 14, 2006 Share Posted September 14, 2006 Thx for the comment on the CD/DVD Combo Drive I'm just looking into updating my computer to run Vista at a good state. I should be good but I might buy more RAM after I see how Vista runs when I get ahold of it Ok, so I changed my Hard Drive. Not bad price... HDD change! I would like to know if all will work out as far as... will my motherboard fit into my case. Will the CPU and Motherboard work together. Windows 7 Ultimate 64-Bit Edition | COOLER MASTER Centurion 590 with 4 120mm Blue LED FANS 1 Regular 120MM FAN and a Custom Window Side Panel | AMD Athlon II x4 2.6GHZ Stock| XIGMATEK HDT-S963 92mm | ASRock A780GXE/128 | G.SKILL 4GB (2 x 2GB) @800MHZ | CF 2 XFX 4850 1GB @GPU940/MEM1005 | 320GB/OS 160GB/Storage HDDs | LG CD/DVD SATA | Rosewill 600W 2 12v Rail@44 | Ccleaner, Defraggler | Malwarebytes', SUPERAnti-Spyware | Avira AntiVir Personal | Google Chrome v3/4, IE8 Link to comment Share on other sites More sharing options...
Eldmannen Posted September 14, 2006 Share Posted September 14, 2006 The motherboard is a mini-ATX with socket 939. The processor is a socket 939 so it fits into the motherboard. The case is an ATX case, so mini-ATX fits into it. The HDD is a Seagate. Seagate is the only harddisk manufacturer with a warranty of 5 years, the other have less, usually 2-3. Link to comment Share on other sites More sharing options...
New_Age Posted September 14, 2006 Share Posted September 14, 2006 Thx, I needed the advice. Windows 7 Ultimate 64-Bit Edition | COOLER MASTER Centurion 590 with 4 120mm Blue LED FANS 1 Regular 120MM FAN and a Custom Window Side Panel | AMD Athlon II x4 2.6GHZ Stock| XIGMATEK HDT-S963 92mm | ASRock A780GXE/128 | G.SKILL 4GB (2 x 2GB) @800MHZ | CF 2 XFX 4850 1GB @GPU940/MEM1005 | 320GB/OS 160GB/Storage HDDs | LG CD/DVD SATA | Rosewill 600W 2 12v Rail@44 | Ccleaner, Defraggler | Malwarebytes', SUPERAnti-Spyware | Avira AntiVir Personal | Google Chrome v3/4, IE8 Link to comment Share on other sites More sharing options...
