BURGUES Jean Paul Posted March 20, 2023 Share Posted March 20, 2023 Pourquoi ccleaner n'élimine plus les cookies de Edge et IE ? Link to comment Share on other sites More sharing options...
Moderators nukecad Posted March 20, 2023 Moderators Share Posted March 20, 2023 Could you expand on your question? There are a few possibilities and the correct answer will depend on just what you are meaning/seeing. What makes you say that they are not being cleared? *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
Robert Dumontet Posted March 21, 2023 Share Posted March 21, 2023 Bonjour tout le monde! Bonjour Nukecad! Le correcteur refuse de nettoyer Microsoft Edge simplement en indiquant qu'il l'ignore. (The fixer refuses to clean Microsoft Edge simply by indicating that it ignores it.) Link to comment Share on other sites More sharing options...
Moderators nukecad Posted March 21, 2023 Moderators Share Posted March 21, 2023 OK, so Custom Clean is telling you that it is Skipping (ignoring) the cleaning of Edge. That is usually because Edge is still running in the background. You need to go into the Edge settings and turn off both 'Startup Boost' and 'Continue running background extensions and apps .....' See the link below for screenshots: OK, donc Custom Clean vous dit qu'il saute (ignore) le nettoyage d'Edge. C'est généralement parce qu'Edge fonctionne toujours en arrière-plan. Vous devez accéder aux paramètres Edge et désactiver à la fois "Startup Boost" et "Continuer à exécuter les extensions et applications en arrière-plan ....."Voir le lien ci-dessous pour les captures d'écran : *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
Guest johnccleaner Posted March 21, 2023 Share Posted March 21, 2023 Cela indique que vous avez sélectionné l'option «Ne me demandez pas à ce sujet» pour ce navigateur dans une invite lorsqu'il vous a demandé la permission de le nettoyer; En tant que tel, le programme ne peut pas vous demander la permission de nettoyer ce navigateur et doit le sauter. Pour annuler cela, veuillez consulter les options> Avancé> 'Restaurer les paramètres par défaut'. Veuillez noter que cela réinitialisera tous les paramètres de CCleaner, alors veuillez d'abord noter tout ce que vous avez changé, comme vos cookies pour conserver la liste, afin que vous puissiez facilement les remettre à nouveau. Une fois cela fait, Ccleaner pourra demander l'autorisation de fermer ce navigateur afin qu'il puisse être nettoyé une fois de plus. Link to comment Share on other sites More sharing options...
Guest johnccleaner Posted March 21, 2023 Share Posted March 21, 2023 N'hésitez pas à essayer d'abord la suggestion de Nukecad; Cependant, si vous avez toujours ce problème, allez-y et essayez le mien. :) Link to comment Share on other sites More sharing options...
