Does not clean Edge Chromium history
Hi all.
CCleaner does not clean Edge Chromium history, as seen from the attached images.
Although it says it has cleared the history data (CC.jpg file), actually the history is still there (Edge.jpg file, with the details blacked out).
In the Edge settings, I disabled fast startup and running in the background.
Any suggestions?
Link to comment
  • Moderators
Is your Edge synced?
Syncing will put back from the cloud whatever browser data CCleaner removes from your machine - that's what sync does.
  • Thanks 1
*** Out of Beer Error ->->-> Recovering Memory ***
Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:
https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043
Link to comment
  • Moderators
Great.
Bear in mind that it's not just the browsing history. It's cookies, Cache, Session, Temporary files, etc. as well.
Whatever browser data CCleaner removes - if you have sync for that data turned on it then it will just be synced back from the cloud again.
CCleaner can clear things from your machine but it can't clear the cloud.
Link to comment
Register a new account
Sign in
Important Information
