FrancisT Posted November 26, 2022 Share Posted November 26, 2022 Using Windows 10 Pro, After the Nov 17th, 2022, update version 4.6.891.1424, Kamo starts fine, except Private Connection that used to start Automatically does not. I have to manually turn on the Private Connection and re-checkmark all the box settings after every system boot or restart. Everything was working fine before the program update, I also checked Task Scheduler which shows Kamo task was updated on 11/17/2022. And is no different from the previous scheduled Task setting. Is this a program change or an error in the software coding, seems like the settings are not being saved for Protection Connection being ON or OFF. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted November 27, 2022 Moderators Share Posted November 27, 2022 Only one topic is needed Please stick to Thank you ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
