markbartlett Posted November 18, 2022 Share Posted November 18, 2022 Why doesn't cc cleaner scan Mozilla for problems I just noticed CC cleaner does not scan the web browser Mozilla or thunder bird Yet it does scan all of microsoft products why would you leave Mozilla out Mark Link to comment Share on other sites More sharing options...
Moderators Nergal Posted November 18, 2022 Moderators Share Posted November 18, 2022 Ccleaner does have routines for both these softwares. In custom clean they are on the second, apps, tab. If they don't show on your pc there, it might be that you chose a non default location for them. This can be resolved with custom loctaion command. https://support.piriform.com/hc/en-us/articles/360048432991-How-to-clean-user-data-from-other-browsers-with-CCleaner-for-Windows#extra-cleaning-for-chromium-or-mozilla-based-web-browsers--0-1 ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
