ChrisM2197 Posted August 29, 2022 Share Posted August 29, 2022 CCleaner remains open in the system tray when the program is closed, with Minimize to System Tray in settings under advanced turned OFF. I am running the latest version of Windows 11 and CCleaner as of this writing. Is this a bug (I assume it is) or is there a setting I am missing to disable this from happening? Link to comment Share on other sites More sharing options...
Moderators Nergal Posted August 29, 2022 Moderators Share Posted August 29, 2022 Turn off both Smartcleaning and auto update ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
ChrisM2197 Posted August 29, 2022 Author Share Posted August 29, 2022 2 minutes ago, Nergal said: Turn off both Smartcleaning and auto update The turning off Auto Updates fixed it. The smart cleaning was already off. Thank you! Link to comment Share on other sites More sharing options...
Moderators nukecad Posted August 30, 2022 Moderators Share Posted August 30, 2022 9 hours ago, ChrisM2197 said: CCleaner remains open in the system tray when the program is closed, ..............., Is this a bug (I assume it is) It isn't a bug, it's simply the way that Windows works. Those options (Smart Cleaning and Auto Updating) each have to run a background process to work properly. So if either one, or both, are enabled then Windows puts an icon in the system tray to show that CCleaner is running something in the background. *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
