TheFiresInTheSky Posted August 18, 2006 Share Posted August 18, 2006 i have an old computer and its been working great till recently, it stopped booting up. nothing on the display. there also isnt any beep coming from the computer anymore. ive tried it on a different monitor just to make sure it was the computer. could it be the HD? Link to comment Share on other sites More sharing options...
MikeW Posted August 18, 2006 Share Posted August 18, 2006 Cmos battery ?? Win 7 Home Premium 64 bit - IE11 - Nod32 - Mbam pro Link to comment Share on other sites More sharing options...
TheFiresInTheSky Posted August 18, 2006 Author Share Posted August 18, 2006 the battery wouldnt have anything to do with that right? it just holds the details like the time and stuff? ill go buy one today and try it. thanks. Link to comment Share on other sites More sharing options...
krit86lr Posted August 18, 2006 Share Posted August 18, 2006 Cmos battery ?? It definitely sounds like a Cmos issue. But if it isn't the battery, couldn't it be a mobo problem too? Windows Pro Media 8.1 x64 | 8GB Ram | 500G HDD 7200 RPM | All that I know about my graphics is that it's Intel Link to comment Share on other sites More sharing options...
MikeW Posted August 18, 2006 Share Posted August 18, 2006 It also protects the bios settings. Flat cmos batt' can happen on old machines that have not been powered up for a long period. Leave the power on for a few hours and then reboot. You may get lucky. You may also have to reconfig bios settings (hard disk type etc) if battery ok. Maybe M'board Win 7 Home Premium 64 bit - IE11 - Nod32 - Mbam pro Link to comment Share on other sites More sharing options...
TheFiresInTheSky Posted August 19, 2006 Author Share Posted August 19, 2006 this is pretty weird. i bought a new battery, put it in, it booted fine. i then started to defrag and it just suddenly reboot. i left it like that for about 15 min then decided to try to reboot again. now it put me right back where i was when i started. could it be the power supply or the HD? also, would it be ok to try to change those out with another old computer that i have? they both run 98SE. thanks for your responses. -aaron Link to comment Share on other sites More sharing options...
Moderators Andavari Posted August 19, 2006 Moderators Share Posted August 19, 2006 Using a Win98 bootdisk run scandisk on the drive and any partitions it may have. If you need something a little quicker than scandisk to do a surface scan let me know, I have a DOS utility that's a s**tload faster and it will actually fix what it finds. Link to comment Share on other sites More sharing options...
TheFiresInTheSky Posted August 19, 2006 Author Share Posted August 19, 2006 ????? how can i fix it if the post screen doesnt even come up? well, actually, i tried Leave the power on for a few hours and then reboot. You may get lucky. and it actually worked. why is that and how can i fix it? andavari, i could use something a little quicker than scandisk, the computer would probably reboot before it got done because the computers a piece of junk, and i dont have a boot disk on me right now. i always lose those things. Link to comment Share on other sites More sharing options...
MikeW Posted August 19, 2006 Share Posted August 19, 2006 You have to let a new cmos battery charge up. Make sure your bios settings are correct specially the hard disk, boot sequence and so on Win 7 Home Premium 64 bit - IE11 - Nod32 - Mbam pro Link to comment Share on other sites More sharing options...
TheFiresInTheSky Posted August 19, 2006 Author Share Posted August 19, 2006 charge up? its a new battery, i dont understand. EDIT: i ran scandisk that was installed in the computer and fixed the errors. im defragging now. after thats done ill try rebooting a few times to see if the problems fixed. Link to comment Share on other sites More sharing options...
MikeW Posted August 19, 2006 Share Posted August 19, 2006 They are a cmos rechargable battery and are often flat when purchased. Therefore power up the pc and leave it on the battery will be charged after a few hours. Dont forget to check your Bios settings. Win 7 Home Premium 64 bit - IE11 - Nod32 - Mbam pro Link to comment Share on other sites More sharing options...
TheFiresInTheSky Posted August 19, 2006 Author Share Posted August 19, 2006 so the cmos battery is different from the battery that i can see and changed? Link to comment Share on other sites More sharing options...
MikeW Posted August 19, 2006 Share Posted August 19, 2006 I know of only one battery soldered to the motherboard Win 7 Home Premium 64 bit - IE11 - Nod32 - Mbam pro Link to comment Share on other sites More sharing options...
TheFiresInTheSky Posted August 19, 2006 Author Share Posted August 19, 2006 interesting, i didnt know they were flat at time of purchase. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted August 19, 2006 Moderators Share Posted August 19, 2006 I thought they were regular flat batteries that were using in for instance a digital wrist watch. Is it really possible that having the PC powered on keeps them charged? Link to comment Share on other sites More sharing options...
MikeW Posted August 19, 2006 Share Posted August 19, 2006 I thought they were regular flat batteries that were using in for instance a digital wrist watch. Is it really possible that having the PC powered on keeps them charged? Yes http://shopping.microbattery.com/s.nl;jses...t=A&id=6555 Win 7 Home Premium 64 bit - IE11 - Nod32 - Mbam pro Link to comment Share on other sites More sharing options...
Moderators Andavari Posted August 19, 2006 Moderators Share Posted August 19, 2006 Yes http://shopping.microbattery.com/s.nl;jses...t=A&id=6555 Interesting. I've never seen a CMOS battery like that one, I've only encountered the type that look like a battery that goes in for instance a Timex, Casio, etc., digital watch. Link to comment Share on other sites More sharing options...
TheFiresInTheSky Posted August 19, 2006 Author Share Posted August 19, 2006 EDIT: i dont know what happened but everythings fixed, its workin fine now! thanks for the help! -aaron Link to comment Share on other sites More sharing options...
