Homero 'Jack' Carreiro Posted May 23, 2022 Share Posted May 23, 2022 A message noticing that "We can not connect you to "Private Connection" at this moment" (in my case the original text is in portuguese) has been shown for some days. What to do to solve this problem? Link to comment Share on other sites More sharing options...
Admin Laurence CCleaner Posted May 24, 2022 Admin Share Posted May 24, 2022 Hi Homero 'Jack' Carreiro,Please can you update to the latest version of Kamo by clicking Menu in the top right corner of the application and then selecting Settings from the menu that appears and the last Check for Updates? If you could let me know if this resolves the issue further for you and if not we will investigate this issue further for you. Link to comment Share on other sites More sharing options...
Homero 'Jack' Carreiro Posted May 26, 2022 Author Share Posted May 26, 2022 On 24/05/2022 at 11:50, Laurence CCleaner said: Hi Homero 'Jack' Carreiro,Please can you update to the latest version of Kamo by clicking Menu in the top right corner of the application and then selecting Settings from the menu that appears and the last Check for Updates? If you could let me know if this resolves the issue further for you and if not we will investigate this issue further for you. Thanks. This was done. The problem is stil there. Link to comment Share on other sites More sharing options...
Guest johnccleaner Posted May 26, 2022 Share Posted May 26, 2022 Please contact our support team via the Contact Us form located here: https://support.piriform.com/hc/en-us/requests/new?ticket_form_id=86507 or by emailing support@ccleaner.com directly and we'll be investigate this matter further. Link to comment Share on other sites More sharing options...
