RTM Posted May 16, 2022 Share Posted May 16, 2022 been a license paying user for years for last 3 weeks when I open cc cleaner takes 30 seconds or more to load ,(Tired of it!) hope you can help me Thanks Richard also tried to get help through the c cleaner app kept throwing capcha s at me Link to comment Share on other sites More sharing options...
Admin Dave CCleaner Posted May 16, 2022 Admin Share Posted May 16, 2022 3 hours ago, RTM said: cc cleaner takes 30 seconds or more to load Which version of CCleaner are you using? If still CCleaner 5.92, does the problem resolve itself after the automatic update to CCleaner 6.0? If it is still slow loading after updating to CCleaner 6.0, can you describe which version of Windows you are using, any AV, firewalls or VPNs active, etc? Piriform Homepage - [CCleaner - CCleaner Mac - CCleaner Android - CCleaner Browser - Recuva - Speccy - Kamo] - Product Support Looking for your licence key, expiry date or download link? Check here first: https://www.ccleaner.com/support/license-lookup To find out how we protect your privacy - read CCleaner's Data Factsheet. What's new? Check the latest CCleaner for Windows release notes. Link to comment Share on other sites More sharing options...
RTM Posted May 16, 2022 Author Share Posted May 16, 2022 yes i am running 6.0 says latest version..., vpn only on browser hardly ever use.. Ive used malwarebytes foever never had problem windows firewall im running windows 11 up to date Link to comment Share on other sites More sharing options...
Guest Andrei CCleaner Posted May 17, 2022 Share Posted May 17, 2022 Hello @RTM, please send an email to our support team at support@ccleaner.com so they could have a look over your situation. Link to comment Share on other sites More sharing options...
RTM Posted May 17, 2022 Author Share Posted May 17, 2022 I fix it! I uninstalled it and cancel my subscription Link to comment Share on other sites More sharing options...
Admin Dave CCleaner Posted May 17, 2022 Admin Share Posted May 17, 2022 2 hours ago, RTM said: I fix it! I uninstalled it I just tried this myself with a stopwatch and on a Windows 10 system under a reasonably heavy load with 100+ other Windows open (consuming ~30% CPU and 80% memory) CCleaner 6.0 takes 2-3 seconds to load for me if Smart Cleaning is enabled (so it was already running in the background) and 3-5 seconds if running it from scratch. So if it is taking 60 seconds or more to load that would seem to suggest that there is something else going on with your computer that you might want to look into. Providing support with log files, etc will help them to see if there is anything specifically on your computer that may be interfering with CCleaner, but also check Task Manager - if you CPU and memory usage are running excessively high then that could be slowing down the loading of any application (and CCleaner's Performance Optimizer might help identify potential hotspots there) Piriform Homepage - [CCleaner - CCleaner Mac - CCleaner Android - CCleaner Browser - Recuva - Speccy - Kamo] - Product Support Looking for your licence key, expiry date or download link? Check here first: https://www.ccleaner.com/support/license-lookup To find out how we protect your privacy - read CCleaner's Data Factsheet. What's new? Check the latest CCleaner for Windows release notes. Link to comment Share on other sites More sharing options...
redwolfe_98 Posted May 18, 2022 Share Posted May 18, 2022 12 hours ago, RTM said: I uninstalled it now that you have uninstalled the pro version, try installing the free version. someone found that the driver-update-backups, used by the pro version, were causing ccleaner to open slowly: https://community.ccleaner.com/topic/63026-ccleaner-gui-takes-too-long-to-launch-try-this/ Link to comment Share on other sites More sharing options...
