gemal Posted March 18 Share Posted March 18 I've turned off automatic updates so I click on the "Check for updates" and when I the get the dialog I click update The last many releases I've gotten the installation program run two times. Latest was today with version 5.9.1 where I again got two dialogs Link to comment Share on other sites More sharing options...
Moderators nukecad Posted March 18 Moderators Share Posted March 18 Just for a bit more info do you have CCleaner Pro or Free version? *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
gemal Posted March 18 Author Share Posted March 18 sorry. The free version Link to comment Share on other sites More sharing options...
Moderators nukecad Posted March 18 Moderators Share Posted March 18 Thanks, not what I was thinking it might be then. Has anybody else seen this happening? *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
Sarex Posted March 21 Share Posted March 21 Same problem, on different computers .. Free version. Two instances of installation start at the same time. Sometimes they close without errors, sometimes they get an error message due to the attempt to write the same file ... In the end, however, the application always restarts. Link to comment Share on other sites More sharing options...
Moderators nukecad Posted March 21 Moderators Share Posted March 21 I've taken a closer look at this and found that if I do a manual update as described then I also get two installation dialogues. In my case one is directly covering the other and so I only see the one unless I drag it from it's default location to uncover the other. It doesn't matter how many times I try it the one is always directly covering the other for me, so wouldn't be noticed unless you drag the top one aside. From what @Sarexsays about sometimes getting an error writing the same file then it appears that it is actually doing two installs at the same time for some reason. Whilst that wouldn't generally be a problem (apart from the occasional write-the-same-file error) it shouldn't be happening. I'll flag it up to the staff/developers. *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
redwolfe_98 Posted March 21 Share Posted March 21 i have ccleaner set to check for updates but not to install the update automatically, so, when there is a prompt to update ccleaner, i then allow the updater to install the update. (i have firefox set the same way, to show when an update is available but to allow me to select to allow the updater to install the update) when there was an update for updating to build 5.89, and 5.90, i would see an error-message when the update was being installed, but the program seemed to be installed properly none the less. i didn't see the same error-message when installing the build 5.91 update. i think that was the problem, what nukecad said, that there were two instances of the update running, but i didn't notice that since the GUI's were on top of each other. the error-message that i would see was "couldn't initialize plugins," something like that. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted March 21 Moderators Share Posted March 21 Maybe that's also a clue to the old "Error opening file for writing" that at this point has been around since at least 2018. Link to comment Share on other sites More sharing options...
redwolfe_98 Posted May 5 Share Posted May 5 this issue needs to be brought to the developers' attention, so that it can be fixed to where, when updating ccleaner, two instances of the installation do not run, together, at the same time. Link to comment Share on other sites More sharing options...
Moderators nukecad Posted May 5 Moderators Share Posted May 5 As said above it has already been brought to their attention. How high a priority it is will be a question for their manager to decide. But as it's only ocassionally causing that 'error writing file', which is easily cured by trying again, then it"s more of an annoyance than a big problem and I don't suppose it will be high up the job list. *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
katlani Posted June 21 Share Posted June 21 This has been happening with every update done via the auto update option. Maybe its not urgent but can cause someone to click on abort instead of ignore. Link to comment Share on other sites More sharing options...
Booker Posted July 1 Share Posted July 1 I get this problem as well with auto update. Running CCleaner free version on Windows 10. It's been happening for a few months. Link to comment Share on other sites More sharing options...
