tazbo Posted January 16, 2022 Share Posted January 16, 2022 I purchased CCleaner Pro. I bought a new laptop with windows 11. I can not figure out how to re register my CCleaner. (my and I are not, unfortunatley, as computer smart as we should be) Thanks for any help Link to comment Share on other sites More sharing options...
Moderators nukecad Posted January 17, 2022 Moderators Share Posted January 17, 2022 There are a few way you can do this. There should be a link in your purchase confirmation email to download CCleaner Pro. Click that link and follow the instructions. Or use the following link to download the CCleaner Pro installer. Double click the downloaded 'ccsetup###_pro.exe' file to install CCleaner - at the end of the install if you leave 'Run CCleaner' ticked it will ask you for your licence key . (If you untick 'Run CCleaner' then it will ask for the key the first time that you do run CCleaner):https://www.ccleaner.com/go/get_ccpro Or you could simply download the CCleaner Free installer from here and then register it:https://www.ccleaner.com/ccleaner/builds If you have CCleaner Free installed (or an unregistered CCleaner Professional) then you have to register it to use the Pro features. Open CCleaner Free. (or unregistered Pro). Go to Options>About>Upgrade to Pro. Enter your registration key as prompted. Click on register. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ More details about registering CCleaner can be found here, with advice and help for if you encounter any problems:https://support.piriform.com/hc/en-us/articles/204043844-How-to-register-and-activate-CCleaner-Professional *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
tazbo Posted January 17, 2022 Author Share Posted January 17, 2022 Ney Nukecad. Thank you very much for your reply. For not being the sharpest tool in the shed, I did save the license key. Thanks again. Tazbo Link to comment Share on other sites More sharing options...
