sussertown Posted December 2, 2021 Share Posted December 2, 2021 ccleaner is stuck in my system tray again. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted December 2, 2021 Moderators Share Posted December 2, 2021 Again? What do you mean? Do you have smart cleaning or fetch updates enabled? What version of windows? What version of ccleaner (don't say latest that means nothing) ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
sussertown Posted December 3, 2021 Author Share Posted December 3, 2021 5.87.9306 Windows 10 pro 64bit. I see no options in the options that would help. Most are unchecked. Link to comment Share on other sites More sharing options...
Moderators nukecad Posted December 3, 2021 Moderators Share Posted December 3, 2021 You have shown 'Advanced' and 'Settings' - Nergal asked specifically about 'Smart Cleaning' and 'Updates'. If either 'Smart Cleaning' or 'Updates' (Keep CCleaner updated automatically) is enabled then Windows will put a CCleaner icon in your system tray. *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
sussertown Posted December 3, 2021 Author Share Posted December 3, 2021 I use custom cleaning. You'll have to provide more information. I can check again for updating. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted December 4, 2021 Moderators Share Posted December 4, 2021 6 hours ago, sussertown said: I use custom cleaning. You'll have to provide more information. I can check again for updating. Smartcleaning is the sixth item in the options left hand menu, please take a screenshot of that. Also eighth item in that list (updates) take a screen shot of that ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators nukecad Posted December 4, 2021 Moderators Share Posted December 4, 2021 If either of those is enabled then Windows will put a CCleaner icon in your System Tray. *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
sussertown Posted December 4, 2021 Author Share Posted December 4, 2021 got it. let's see if this works. Link to comment Share on other sites More sharing options...
