Speccy showing wrong cpu info
david17
  • Moderators
sprccy pulls from windows' wmi feature.  However, depending on how new your cpu is, speccy being outdated and long overdue for an update, the info may not be compatible with the program
Link to comment
perhaps the virtualization option at the bios is not activated?
Versions of CCleaner Cloud; Introduction Ccleaner Cloud;
Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free
Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard"
Link to comment
Register a new account
Sign in
Important Information
