jqa2003 Posted August 30, 2021 Share Posted August 30, 2021 I keep on getting a notification every 5 minutes saying Ccleaner has cleaned edge chromium including when I am not using it . How do I stop it? Link to comment Share on other sites More sharing options...
Admin Dave CCleaner Posted August 30, 2021 Admin Share Posted August 30, 2021 That is unexpected. The maximum frequency of the scheduled cleaning (if you have set it up under Options > Scheduling) is daily. It may pop up more frequently if you have it set to clean Edge every time it closes (under Options > Smart Cleaning), and to notify you of the fact, and you are opening and closing Edge frequently. But that does not sound like it is the case from your description. Can you confirm: Your version of Windows (eg: Windows 10 21H1, etc) Your version of Edge (the three dots > Help > About Microsoft Edge) Your version of CCleaner Were there any other apps that you were actively running at the time (possible that one of them might have been using an embedded browser)? Piriform Homepage - [CCleaner - CCleaner Mac - CCleaner Android - CCleaner Browser - Recuva - Speccy - Kamo] - Product Support Looking for your licence key, expiry date or download link? Check here first: https://www.ccleaner.com/support/license-lookup To find out how we protect your privacy - read CCleaner's Data Factsheet. What's new? Check the latest CCleaner for Windows release notes. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted August 30, 2021 Moderators Share Posted August 30, 2021 also some windows store app now run edge (facebook for one) and ask for cleaning after they close. Are you exiting any program when you see those alerts ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
jqa2003 Posted August 30, 2021 Author Share Posted August 30, 2021 2 hours ago, Dave CCleaner said: That is unexpected. The maximum frequency of the scheduled cleaning (if you have set it up under Options > Scheduling) is daily. It may pop up more frequently if you have it set to clean Edge every time it closes (under Options > Smart Cleaning), and to notify you of the fact, and you are opening and closing Edge frequently. But that does not sound like it is the case from your description. Can you confirm: Your version of Windows (eg: Windows 10 21H1, etc) Your version of Edge (the three dots > Help > About Microsoft Edge) Your version of CCleaner Were there any other apps that you were actively running at the time (possible that one of them might have been using an embedded browser)? Windows is 10.21H1 Edge is Version 92.902.84 (office build) (64 bit) Ccleaner is V5.84.9126(64 bit) I closed edge and got notification the Ccleaner cleaned edge then when I opened Google chrome it popped up again and again 2seconds later while I was on Chrome. It used to pop up when ever I closed Edge andnow it pops up no matter what browser I am using saying it has cleaned edge Link to comment Share on other sites More sharing options...
Moderators nukecad Posted August 30, 2021 Moderators Share Posted August 30, 2021 As Edge is now Chromium based this sounds like some mix up between Edge chromium and Chrome itself. My thinking is that Edge is leaving something running (or restarting something) in the background that opening Chrome itself then closes again; thus giving the message that Edge has closed (again). Could you tell us if you have any extensions/add-ons/plug-ins enabled in Edge? And then any in Chrome? PS. Those notifications can be turned off - but it's better to find what is causing them and stop that from causing them in the first place. *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
jqa2003 Posted August 30, 2021 Author Share Posted August 30, 2021 4 hours ago, nukecad said: As Edge is now Chromium based this sounds like some mix up between Edge chromium and Chrome itself. My thinking is that Edge is leaving something running (or restarting something) in the background that opening Chrome itself then closes again; thus giving the message that Edge has closed (again). Could you tell us if you have any extensions/add-ons/plug-ins enabled in Edge? And then any in Chrome? PS. Those notifications can be turned off - but it's better to find what is causing them and stop that from causing them in the first place. No I don't have any extensions/.add -ons /plug-ins enabled in Edge Link to comment Share on other sites More sharing options...
Moderators nukecad Posted August 31, 2021 Moderators Share Posted August 31, 2021 Could you give us a screenshot of your Smart Cleaning settings? *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
jqa2003 Posted August 31, 2021 Author Share Posted August 31, 2021 Link to comment Share on other sites More sharing options...
Moderators nukecad Posted August 31, 2021 Moderators Share Posted August 31, 2021 Sorry but that's the wrong page, the Smart Cleaning like this: PS. You can use 'alt+prt scr' to screenshot just the active window rather than the full screen. Or use 'Snip & Sketch' from the Start menu to caputre a smaller area like I did there, once you've captured a snip you can paste it straight into your post. If you could also capture the notification that you are seeing then that should help us see just what is causing it. *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
jqa2003 Posted August 31, 2021 Author Share Posted August 31, 2021 Sorry I don't know what you are on about that is the screenshot for smart cleaning Link to comment Share on other sites More sharing options...
Moderators Nergal Posted September 1, 2021 Moderators Share Posted September 1, 2021 Your image shows the first page of ccleaner settings, click the smart cleaning button sixth button down 6 hours ago, jqa2003 said: Sorry I don't know what you are on about that is the screenshot for smart cleaning ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators nukecad Posted September 1, 2021 Moderators Share Posted September 1, 2021 Look at the things highlighted in blue. In your screenshot it's "Options" and "Settings". in my screenshot it's "Options" and "Smart Cleaning". *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
jqa2003 Posted September 1, 2021 Author Share Posted September 1, 2021 1 hour ago, nukecad said: Look at the things highlighted in blue. In your screenshot it's "Options" and "Settings". in my screenshot it's "Options" and "Smart Cleaning". Link to comment Share on other sites More sharing options...
jqa2003 Posted September 1, 2021 Author Share Posted September 1, 2021 Sorry cannot send you screenshot of me getting message that Ccleaner has cleaned Edge This happened as soon as I got on computer and before I opened Edge this morning Link to comment Share on other sites More sharing options...
Moderators nukecad Posted September 1, 2021 Moderators Share Posted September 1, 2021 That's good, so you have all your browsers set to clean when closed, and to notify you that the cleaning has been done. You have two options; We can keep working to try and find out why your Edge Chromium is constantly opening and closing on your machine. (That could be a fault in Edge itself, or another Microsoft app that is opening/closing Edge on a schedule, or a bit of both). You can ignore that it's happening and simply tell CCleaner not to give you any notification about Edge Chromium being closed. (That doesn't cure what is causing it to keep opening/closing but stops ccleaner telling/nagging you about it). If you choose the second one then on that screen where it says "Automatically clean on closing with notification" next to Edge Chromium click the little down-arrow. You can then choose from: "Automatically clean on closing without notification" - Smart Cleaning will keep cleaning it (every time it closes) but won't give you the notification. "Disabled" - Smart Cleaning will not keep cleaning it. You'll need to run CCleaner manually to clean it. (The other 3 options there will all give you a notification about something). Agian: Note that if you use one of those option you are not stopping whatever keeps opening/closing Edge Chromium, you are just telling CCleaner not to tell you about it. Now as to what is the cause of the problem, you last post may give a clue: Quote ..... message that Ccleaner has cleaned Edge This happened as soon as I got on computer and before I opened Edge this morning That could indicate that Edge is trying to load in the background when you start your machine, but is crashing for some reason. That isn't so unusual and you can try some of the fixes here: Note that the first thing it tells you to do is run CCleaner, I think you can safely say you've already done that, - but do 'Restart' your machine before trying any of the other fixes. Note - that's a "Restart" (Click the Windows Start icon, click Power, click Restart) and not a Shutdown. Then try the other fixes one at a time, checking after each one to see if Edge is now behaving itself. https://windows101tricks.com/microsoft-edge-closes-immediately/ *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
Moderators nukecad Posted September 1, 2021 Moderators Share Posted September 1, 2021 @jqa2003 I assume that's your screenshot of the notification that wouldn't post for you? At least we can see it now, For some reason it seems to have now attached itself to the bottom of my latest post, and my latest screenshot has also repeated itself. The forum software occasionally works in mysterious ways. I'll leave them where they are for now, I don't want to edit that post further while I ask the Forum Administrator take a look at what happened. *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
jqa2003 Posted September 1, 2021 Author Share Posted September 1, 2021 10 hours ago, nukecad said: @jqa2003 I assume that's your screenshot of the notification that wouldn't post for you? At least we can see it now, For some reason it seems to have now attached itself to the bottom of my latest post, and my latest screenshot has also repeated itself. The forum software occasionally works in mysterious ways. I'll leave them where they are for now, I don't want to edit that post further while I ask the Forum Administrator take a look at what happened. It was another notification The other one was taken 1/2 hr after I closed Edge Anyway I have decided to disable the notification. Thanks for the help Link to comment Share on other sites More sharing options...
Moderators nukecad Posted September 2, 2021 Moderators Share Posted September 2, 2021 11 hours ago, jqa2003 said: Anyway I have decided to disable the notification. That's your choice, and the easiest way to stop the notifications. But you should be aware that whatever is causing Edge to open/close every 5 minutes like that will still be happening; you just won't have CCleaner telling you about it. Whatever is causing the odd behaviour with Edge may also give you other odd problems elsewhere. (Or Edge may just fix itself with the next Windows cumulative update?) If/when you have time it may be worth looking at those fixes for Edge in the link I gave, just to be on the safe(er) side. PS. The issue with the screenshot attachment being in the wrong post (my post instead of yours) is a bug in the software that the forum runs on. I've also seen it happen on another forum (Malwarebytes Forum) that runs on the same forum software. It's very unusual, but something that the makers of the forum software will have to look at. *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
