rodes Posted June 17, 2021 Share Posted June 17, 2021 CCleaner hangs up when cleaning and when updating drivers Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted June 18, 2021 Moderators Share Posted June 18, 2021 I have pointed admins to this post. Support contact https://support.piriform.com/hc/en-us/requests/new?ticket_form_id=86507 support@ccleaner.com Link to comment Share on other sites More sharing options...
Admin Azra CCleaner Posted June 18, 2021 Admin Share Posted June 18, 2021 Hi @rodes If you are still experiencing the same issue, Our support team would be happy to help with this and you can easily contact them via email, using support@ccleaner.com. Link to comment Share on other sites More sharing options...
Bebbspoke Posted June 18, 2021 Share Posted June 18, 2021 I have similar issues - I contacted the support team who initially replied in French... (for no apparent reason)... I am awaiting a second response - I find the "Driver Updater" to have serious issues with hangs and "cannot update your dirvers" problems; - CCleaner identifies some 15 drivers it "cannot update" but the links for user to cross reference such "cannots" are suspect. I've used the freebie version of CCleaner for years; - now I'm really NOT IMPRESSED with the "Pro" version. Link to comment Share on other sites More sharing options...
boucehpat Posted June 18, 2021 Share Posted June 18, 2021 Same problems here. The first time it managed to update a couple of drivers (out of 18 which seems weird to me), then errors out. Attempted a second time, now message hangs on "Updating x out of x drivers" . x is blank no numbers. Rebooted computer, out of 4 screens only 2 are detected, re-rebooted and all 4 screens are detected. Guessing it attempted to update the docker station and messed it up, thankfully the reboot fixed this! Using the pro version, should be looking into the issues instead of asking customers to contact support... Link to comment Share on other sites More sharing options...
Moderators Nergal Posted June 19, 2021 Moderators Share Posted June 19, 2021 Moderators are just users like you we can just ban spammwrs. We have very little information past what you do, especially about brand new features like driver updater ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
TheAncient Posted June 19, 2021 Share Posted June 19, 2021 Having problems with the new 'alpha' version of the Driver Updates function as well: * On one machine, the USB Keyboard will not work after driver update. * On another machine, the display goes "wonky" (far too large and distorted) after driver update. On this machine, even using the "revert" option does not actually 'revert': the display remains distorted and I had to re-load the entire machine from backup. * On some machines some driver updates fail. * On ALL of my machines, when trying to 'skip' a driver, the program hangs and has to be closed manually. Looking forward to a 'beta' version... (I wish you would tell us when you are pushing out unfinished software and use your paying customers as guinea pigs) Link to comment Share on other sites More sharing options...
TheAncient Posted June 19, 2021 Share Posted June 19, 2021 According to Driver Updater, I have ZERO drivers on my system! I wonder how, without a display driver, I am able to even look the output from driver updater.. Link to comment Share on other sites More sharing options...
