gmxd 0 Posted March 12 Share Posted March 12 CCleaner with smart cleaning enabled for Edge Chromium will kill the CCleaner Process. Installed CCleaner Version V5.77.8521. Link to post Share on other sites
Moderators nukecad 9 Posted March 12 Moderators Share Posted March 12 Are you saying that when you close Edge Chrome Smart Cleaning runs but then closes itself? Was it working OK until recently? If so then it's possibly/probably because of the new 'Startup Boost' in Edge Chrome, it leaves background processes running so CCleaner can't clean it properly. Try turning 'Startup Boost' off.https://www.bleepingcomputer.com/news/microsoft/microsoft-edge-is-now-41-percent-faster-with-new-startup-boost-feature/ *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to post Share on other sites
gmxd 0 Posted March 12 Author Share Posted March 12 Are you saying that when you close Edge Chrome Smart Cleaning runs but then closes itself? YesWas it working OK until recently? Yes But i found out the reason now. I installed Ashampoo Snap 12 some days ago. When Snap12 is disabled, CCleaner works fine. Link to post Share on other sites
Moderators nukecad 9 Posted March 12 Moderators Share Posted March 12 Thanks for sharing that, it may be helpful to others. (And to the Ccleaner developers). I don't know that app, or why it should give a problem with cleaning Edge Chrome in particular. I'll pass your findings upwards. *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to post Share on other sites
Moderators nukecad 9 Posted March 15 Moderators Share Posted March 15 @gmxd Update: The staff have comfirmed that they can replicate this issue with Ashampoo Snap 12 and the developers are investigating. Thanks again for the report. *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to post Share on other sites
