Mark_R Posted December 2, 2020 Share Posted December 2, 2020 Hello! I have a USB that I saved files on but it is now undetectable. I have tried the USB on 2 windows computers and 2 Macs, and each time nothing appears in File Explorer and no sound of recognition of anything being inserted into the USB drive. I have downloaded the Recuva program but it requires a location to be indicated...and since the USB is not being recognised, there is no external location (only local disk, as on screenshot attached). Can you please help? Link to comment Share on other sites More sharing options...
Guest johnccleaner Posted December 2, 2020 Share Posted December 2, 2020 Recuva will not be able to work in this situation, as it requires that the drive be accessible in Windows and mounted with a drive letter. Unfortunately, given that you're not getting any sort of reaction from it on four different computers, that sounds very much like the drive itself has failed. Most likely, the only feasible option for getting data off of this drive will be to take it to/send it into a proper data recovery service. Link to comment Share on other sites More sharing options...
Mark_R Posted December 2, 2020 Author Share Posted December 2, 2020 Understood, thank you Johnccleaner, I was thinking that this might be the case, but wanted to try one last opportunity. Link to comment Share on other sites More sharing options...
