TJP 0 Posted November 28, 2020 Share Posted November 28, 2020 Recently, Like with the last couple of days, the font color and size appear to have changed on my CCleaner dashboard / window. Between the very light blue/grey color and size the are almost unreadable. I noticed this after the most recent update was installed. Any help or suggestions on correcting this ? Thanks Link to post Share on other sites
Moderators nukecad 7 Posted November 28, 2020 Moderators Share Posted November 28, 2020 CCleaner hasn't changed so it must be your Windows setup. Can you post a screenshot of what you are seeing? *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to post Share on other sites
Moderators Andavari 1 Posted November 28, 2020 Moderators Share Posted November 28, 2020 Could be the Windows scaling. Also see if you've had any recent automatically installed display/graphics driver updates, I remember in the past (not on Win10) whenever an update was installed it also defaulted the screen to the native resolution making text too small. Link to post Share on other sites
TJP 0 Posted November 29, 2020 Author Share Posted November 29, 2020 Here's a screen shot, If the fonts were as dark as they appear below in the second column, it would help a bunch but they are real light colored similar to the unchecked options. I will check on my laptop to see if it is the same and report back in a bit. Googling as well as checking this forum, reveals the issue shows that it has been around before. Thanks for trying to help Link to post Share on other sites
Moderators Andavari 1 Posted November 30, 2020 Moderators Share Posted November 30, 2020 It's the greyed out unselected items? If so allot of programs do that, whereas some don't. Link to post Share on other sites
TJP 0 Posted November 30, 2020 Author Share Posted November 30, 2020 No, they are all about the same. If the checked boxes were as dark as they are in the posted screen shot that would help a lot, but they're not. I'm puzzled as to why the screen shot looks so different than my monitor?? Might have to check the contrast settings, but I don't want to screw up all the other places / programs because of this one Link to post Share on other sites
Moderators nukecad 7 Posted November 30, 2020 Moderators Share Posted November 30, 2020 It does sound as if it's a Windows setting doing this. As you say it's odd that the screenshot should be different from what you are seeing. Maybe check the Windows Night Light settings and times? Or it could be down to a theme that you are using which would be in personalisation rather than display settings? Or maybe a manufacturer specific display driver/app that shipped with your computer? TBH there are so many different things that could be causing it. *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to post Share on other sites
