CCleaner Community Forums
Defraggler seems to leave data scattered after hours of processing it's system
I just recently bought Defraggler so I'm not sure what to expect.  However from my experience with similar products in the past, I expected that after several hours of processing my data, defragging and placing it most efficiently, that the graphic would show, no more defragged blocks, and the data represented would be contiguous, not scattered all over my drive.  Additionally when it finished after two passes to make it appear as I expected it still shows similarly and shows 13% FRAGMENTED!
I've tried quick defrag, regular defrag and defrag on unused blocks and it still appears the same.  What am I doing wrong or is this normal?  Thanks for your help.  Ron
Link to post
  • Moderators
Defraggler as default runs a combination of defragment and consolidate. (They are two different things although both are refered to as simply defragmenting).
Defragmenting puts each individual file into one piece so that it can be accessed (slightly) more quickly.
Consolidation put all the files as close together as possible (contiguous) to save space on the drive.
As said, by default Defraggler does a combination of the two to try and give you the best of both. - But you can force it to do either one or the other.
If you do an Analyze and then 'View files', select the files and defrag selected, that that will defrag the files without consolidation.
If instead you go to the menu at the top and select Action>Advanced>Defrag Freespace that should consolidate the files and make them as contiguous as possible.
There are two options for Defrag Free Space,
 Defrag Freespace - will keep the files in one piece and so may leave some empty space in clusters.
Defrag Freespace (allow fragmantation) - will attempt to fill up the clusters entirely, which means that some files will be fragmented to fill them up.
Note that some files are 'pegged' to locations on the disc and so cannot be consolidated in this way.
Sometimes that is because they are in use (certain Windows defender files for example), sometimes Windows has pegged them to a specific location (The Windows pagefile being the classic example).
Try a 'Boot Time Defrag' from the Settings menu to see if it will defrag/consolidate those.
What type of drive is it (HDD or SSD) and how big?
I expect it to be in the TB range if it's taking hours to defrag.
Here's a screenshot of my C drive drivemap after a Defrag Freespace and then a files only defrag.
The analyze took about 30 seconds, defrag freespace about 2 mins (it was pretty good already), the files only defrag took about 15 mins but I was also working online while it was running.
As you can see it's now reporting 0% fragmented, most of the clusters are contiguous, but there are freespace gaps because some files are 'pegged' to their locations on the disc.
Note in particular those 4 lower clusters, they have system files in them and never get moved. (Although a 'Boot Time Defrag' from 'Settings' may be able to do that, I've not run that in a while. - I do know that's the only way to defrag the Windows Pagefile, my pagefile used to be in two blocks but as you can see it's now consolidated).
*** Out of Beer Error ->->-> Recovering Memory ***
Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:
https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043
Link to post
This is about as complete an answer to a technical question as I've ever had in my experience.  Thank you so much for the time you would take to explain this.  Now I have a reference point to come back to as I use the system even if it is not totally clear to me as the neophyte I am at the moment.
I sincerely appreciate you doing this for me.  Thanks,  Ron
PS  My drive is a 500 gig HDD only using about 314g for data and about 185g free.  Seems like an extraordinarily long time to process to me at about an eight hour average so far.  👍
Link to post
  • Moderators
Don't know why it's taking so long for you.
If the disc/files were badly fragmented to start with it could take a few long runs to get it all organised.
The other main factors are how much free space there is on the disc (the more the better), how much RAM you have (the more...), how fast your CPU is (the faster ...), and if you or your computer is doing anything else at the same time.
And of course how you personally use your computer and what for.
As I say Defraggler tries to do the best of both defrag and consolidate so if you defrag once a week then things should get more organised over time and change the balance,  and so get quicker to run. (Like I said above about my consolidation already being pretty good, so Defraggler spent more time on newly defragmented files).
Link to post
Register a new account
Sign in
