Will CC cclean up after me?
Trying to uninstall a program. Its uninstaller fails because of missing file unins000.dat. CC has an entry for the prog but tells me the prog 'does not exist.'I want to just go into its \ProgramFiles directory and delete its fiiles and subdirs manually.
Will CC clean up the registry mess after me? Thanks for help.
Link to comment
14 hours ago, hazelnut said:
What is the program? COLD TURKEY BLOCKER
Are you able to re-install it so that it will reinstall the missing unins000.dat ? HAVE NOT TRIED YET
Was able to reinstall and missing file reappeared. Then able to do a normal UNinstall. Seems to be clean
Link to comment
Register a new account
Sign in
Important Information
