Marcus_MONR Posted July 2, 2020 Share Posted July 2, 2020 (edited) So if i check my CPU, it says "Intel Core i7 7700" (with "Speccy") but if I check the specifications of the CPU it says that the CPU is a "Intel Core i7-9700K CPU @ 3.60GHz" I am not sure if this is normal, and I would just like to know if something is wrong. Thanks. Edited July 2, 2020 by Marcus_MONR I used theSpeccy program btw Link to comment Share on other sites More sharing options...
Moderators Nergal Posted July 3, 2020 Moderators Share Posted July 3, 2020 Speccy for desktop is in quite a need for an update. Many newer hardware are currently mislabeled. I've moved this to the speccy bugs board ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators Andavari Posted July 3, 2020 Moderators Share Posted July 3, 2020 Some other more up-to-date tools will list what family an Intel processor is in, and it can reference something older than what's actually installed in the computer. Link to comment Share on other sites More sharing options...
