herbalist32 Posted April 5, 2020 Share Posted April 5, 2020 Have tried everything Ccleaner support has suggested. {removed} days of getting No where. Can not maintain and use Ccleaner Pro on my win10 pc. Worked fine for a year, then recently da!!?? - Can download sometimes and run it once. Then when I click it on desktop, or on toolbar - NOTHING!!?? {removed} Link to comment Share on other sites More sharing options...
Moderators Nergal Posted April 5, 2020 Moderators Share Posted April 5, 2020 Please don't publicize your email address like that it makes both you and the forum less safe. Not sure why you think we users will be better than support but i'll try. What antivirus do you use? The fact that it starts once and then won't work sounds like a problem Trend Micro users are experiencing. I don't understand when you say "Worked fine for a year, then recently da!!??" Did it stop working with the new update that came out on march 24, or were you experiencing this before then? ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators nukecad Posted April 5, 2020 Moderators Share Posted April 5, 2020 Don't mean to tread on your toes Nergal but i thought those links were better removed. *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
Moderators Nergal Posted April 5, 2020 Moderators Share Posted April 5, 2020 38 minutes ago, nukecad said: Don't mean to tread on your toes Nergal but i thought those links were better removed. I tried to remove it and the forum software kept linking it, it was his email address but the "mailto" command wouldn't leave. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators nukecad Posted April 5, 2020 Moderators Share Posted April 5, 2020 IP board can be very strange at times. *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
