Cube_6_Res Posted March 27, 2020 Share Posted March 27, 2020 I want to launch CCleaner at the end of my browsing session, but it won't launch. I re-installed yesterday, and it worked. but today, it won't. Is anyone else experiencing this problem? Windows 10, 1TB SSHD, 12 GB Ram. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted March 27, 2020 Moderators Share Posted March 27, 2020 Are you using free or pro ccleaner? ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
clarek Posted March 27, 2020 Share Posted March 27, 2020 I'm having the same issue - free version. I tried updating, then reinstalling and no luck. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted March 28, 2020 Moderators Share Posted March 28, 2020 What anti virus are you using? Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
clarek Posted March 28, 2020 Share Posted March 28, 2020 Trend Micro Link to comment Share on other sites More sharing options...
Moderators nukecad Posted March 28, 2020 Moderators Share Posted March 28, 2020 Another user reports that once Trend Micro is updated to 2020 then CCleaner works as expected again.https://community.ccleaner.com/topic/57718-ccleaner-not-opening/?tab=comments#comment-317551 Updating Trend Micro from within Trend Micro itself will tell you that you are up to date - but you may not be. You may have the 2018 or 2019 versions of TM, so while that is up to date itself - it is not the latest TM version. You may need to download and install the TM 2020 upgrade - go to this page to 'grab' the 2020 upgrade.https://esupport.trendmicro.com/en-us/home/pages/technical-support/maximum-security/home.aspx *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
