CCleaner Community Forums
Sign in to follow this
ungars
Library not loaded: @executable_path/../Frameworks/CCleanerLib.framework/Version
Hello,
I have one message every second by "/Library/PrivilegedHelperTools/com.piriform.ccleaner.CCleanerAgent",
but the LIB Frameworks/CCleanerLib.framework/Versions/A/CCleanerLib exists at the right place... :
Process:               com.piriform.ccleaner.CCleanerAgent [2865]
Path:                  /Library/PrivilegedHelperTools/com.piriform.ccleaner.CCleanerAgent
Identifier:            com.piriform.ccleaner.CCleanerAgent
Version:               1.17
Code Type:             X86-64 (Native)
Parent Process:        launchd [1]
Responsible:           com.piriform.ccleaner.CCleanerAgent [2865]
User ID:               0
Date/Time:             2020-03-06 19:04:56.719 +0100
OS Version:            Mac OS X 10.13.4 (17E199)
Report Version:        12
Anonymous UUID:        <deleted>
Time Awake Since Boot: 1900 seconds
System Integrity Protection: enabled
Crashed Thread:        0
Exception Type:        EXC_CRASH (SIGABRT)
Exception Codes:       0x0000000000000000, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Reason:    DYLD, [0x1] Library missing
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
  Library not loaded: @executable_path/../Frameworks/CCleanerLib.framework/Versions/A/CCleanerLib
  Referenced from: /Library/PrivilegedHelperTools/com.piriform.ccleaner.CCleanerAgent
  Reason: image not found
Binary Images:
       0x109ad5000 -        0x109ae1ff7 +com.piriform.ccleaner.CCleanerAgent (1.17) <5A7C3412-A73E-3E78-BB1C-C41D1967D8A1> /Library/PrivilegedHelperTools/com.piriform.ccleaner.CCleanerAgent
       0x10d9c5000 -        0x10da0f9df  dyld (551.3) <AFAB4EFA-7020-34B1-BBEF-0F26C6D3CA36> /usr/lib/dyld
So I have uninstalled CCleaner...This message is not...clear 😲
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
Loading...
