Lynt123 Posted February 26, 2020 Share Posted February 26, 2020 I know that edge has pre loading and this needs to be disabled in order to properly use CC on it. Now that IE11 is 'unsupported' by Microsoft they are pushing the Edge. many of us are still running 32 bit OS (win 7 or earlier). Are there plans to include Edge in the autodetect and auto populate fields? Even if CC just cleans the cookies, browser history, search history that would be a big step in including 32 bit users. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted February 26, 2020 Moderators Share Posted February 26, 2020 It is coming in the next version which we were told should be early march (or even maybe in the next three days though I doubt it) ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
