par0x Posted June 26, 2006 Share Posted June 26, 2006 Hey, ive formatted and nstalled windows xp on my machine problem is i deleted the windows folder off the cd and i installed xp it installed onto the E drive and now i get a message saying NTLDR is missing press ctrl+alt+del to restart will anyone be able to make some files to format c:\ and e:\ drive and then run the windows xp CD fromm the floppy thanks, Link to comment Share on other sites More sharing options...
AndyManchesta Posted June 26, 2006 Share Posted June 26, 2006 Hi Par0x, I got the PM but Im afraid its not something I know anything about, there is multiple results on this using search engines but the solution doesnt seem simple, Maybe other members can give you some detailed advise on this http://support.microsoft.com/?kbid=320397 http://search.microsoft.com/results.aspx?q...&FORM=QBME1 Andy Link to comment Share on other sites More sharing options...
krit86lr Posted June 26, 2006 Share Posted June 26, 2006 Could you clearify your situation? I'm not sure what it is that you need. You can get XP Floppy setup disks from MS's website if that's all that you're looking for. It takes 6 diskettes total, so have them ready. I'm not sure exactly what you did. Hope that helps. Windows Pro Media 8.1 x64 | 8GB Ram | 500G HDD 7200 RPM | All that I know about my graphics is that it's Intel Link to comment Share on other sites More sharing options...
TheFiresInTheSky Posted June 26, 2006 Share Posted June 26, 2006 i think he installed windows on E: and he wants it on C: its set to boot from C but not E. can you boot up windows at all? and to format, i think you can use the windows cd. Link to comment Share on other sites More sharing options...
krit86lr Posted June 26, 2006 Share Posted June 26, 2006 i think he installed windows on E: and he wants it on C: its set to boot from C but not E. can you boot up windows at all? and to format, i think you can use the windows cd. If he installed Windows on E, and wants it on C...then he needs to reinstall? Hey, you could also change the letters. You could make C...E, and E...C. There are a few different things you could do in this situation actually. In, my opinion you should fix your CD before doing anything. Windows Pro Media 8.1 x64 | 8GB Ram | 500G HDD 7200 RPM | All that I know about my graphics is that it's Intel Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted June 27, 2006 Moderators Share Posted June 27, 2006 A bit more reading for you parOx http://www.computerhope.com/issues/ch000465.htm This one has a download link for a floppy fix for 'ntldr is missing'. http://www.tinyempire.com/shortnotes/files/ntldr_missing.htm Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
medab_1 Posted June 27, 2006 Share Posted June 27, 2006 Can you set the computer to boot from the E: drive? At start up there should be an F key to press to enter setup or boot up options. Link to comment Share on other sites More sharing options...
TheFiresInTheSky Posted June 28, 2006 Share Posted June 28, 2006 you need to enter the bios. try: F1, F2, F3, F4, Del., B, or Enter. there could be more but those are the probable ones. look on the screen when it first starts to boot up, it usually shows up what key to press. Link to comment Share on other sites More sharing options...
par0x Posted June 28, 2006 Author Share Posted June 28, 2006 works now, just formatted again, downloaded a file onto a floppy to fix it. thanx anyway Link to comment Share on other sites More sharing options...
