CCleaner Community Forums
Dupe files not deleted, system restore blank
Thank you. I'm also running 10. Whose default is "restore disabled," Windows or CC? Can it be enabled? I feel like I paid for something with CC Pro that I'm not getting.
Link to post
(Doesn't CCPro paid include product support, not community?) Use dupe files finder, check files to be deleted, click DELETE. Almost none (perhaps none) of selected files are deleted.
System Restore is blank.
CCPro. Windows 10
Link to post
  • Moderators
You can find the pro support link in my signature below this post.  Be sure to use the same email address you used to register.
Link to post
  • Moderators
It's a setting in Windows, see this for how to turn it on/off :
https://www.thewindowsclub.com/system-restore-disabled-turn-on-system-restore-windows
EDIT: Once you have turned it on it will take some days/weeks for Windows to build up a list of restore points.
You can manually create one straight away when you turn it on, there is a 'Create' button, see the first screenshot in the link above.
Then Windows creates them on a schedule, or when there is a Windows Update,
PS. Note that is the free version, Manage Restore points is not only a CC Pro feature it's in the Free version too.
Link to post
  • Admin
Yes it does - but for issues relating to both the free and paid product, mentioning it here (if it's not already covered in a previous post or in the product documentation or FAQ files) can benefit the rest of the community who may be looking for the same thing.
Link to post
Register a new account
Sign in
