jcperr35 Posted May 5, 2019 Share Posted May 5, 2019 (edited) Bonjour, Depuis quelques temps, je rencontre le PB suivant. Lors du lancement du PC, deux messages identiques s'affichent l'un après l'autre, immédiatement après un autre message identique avec une réponse oui ou non. Edited May 5, 2019 by jcperr35 Modification Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted May 5, 2019 Moderators Share Posted May 5, 2019 Pouvez-vous utiliser Google Translate pour poster en anglais s'il vous plaît. Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators Nergal Posted May 6, 2019 Moderators Share Posted May 6, 2019 Duplicate thread closed Dupliquer le fil fermé ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
