CCleaner Community Forums
Georg Metzger
Enormous problem with NTFS compressed files
I am experiencing huge problems with a harddisk that contains a lot of highly compresses files (on filesystem level).
Example: The disk is 350GB, has 280GB free space and contains 400GB of data (as I said, the files are highly compressed).
All calculations of Defraggler are totally wrong, speed is extremely poor.
It looks like Defraggler is looking for free space for the new file, but BASED ON THE REAL FILESIZE, not based on the COMPRESSED size (i.e. the required space).
I do not know if my assumption is correct, of course, but I see that the green bar for the new file has the length the uncompressed file would have. After the file is moved, the really used space is totally diffrerent.
Additionally, the files have 5 MILLION fragments and this huge number seems also to be a problem.
Defragging using the normal command, also defragging free space is ultimately slow, Defragging single files (also with many selected) seems to be faster.
This makes Defraggler unusable with NTFS-compressed files.
Update:
Defraggler startet to do some strange things after it was not able to find enough free space for a file (with uncompressed size). The occupation map changed constantly and totally.
This program does not seem to reliable. If it is doing unexplainable things with my valuable data, I can not use it!
Share this post
Link to post
hi Georg and welcome.
but to clarify...
the disk has 350GB capacity.
280GB free space.
and contains 400GB of data.
I want to see that pie chart :blink: - fire up File Explorer, right click that drive and select Properties.
attached a Snip of that screen and attach it here.
doesn't matter how highly compressed that drive is, you still can't fit a square peg into a round hole.
Share this post
Link to post
The disk does not exist anymore in the mentioned form.
I found another free defragger that was able to do the job very quickly.
It has been transformed now to 110GB with 30GB free and 300GB of data. That was the whole idea behind it all: I wanted to reduce the size of the disk (which is a VHD file, really, used in a VM)
But the pie chart looked totally normal in Defraggler, too, as well as the occupied space in numbers: 80 GB of 350 GB were occupied, pie chart looked like a quarter filled.
Share this post
Link to post
ok, glad you got it sorted.
Share this post
Link to post
Yes, I got it sorted. But NOT with Defraggler...
And I think you should address this issue, because it is really a big problem of your software...
Share this post
Link to post
Hopefully the Devs will see this.
as to any sort of outcome, who knows.
Share this post
Link to post
There should be some sort of outcome, in your own interest...
Currently, DiskDefraggler is not usable for drives that contain (a lot) NTFS compressed files...
Share this post
Link to post
Hi! - Sincerely apologise if I am crossing threads. The topic here seems so similar.
I am fine with Defrag, though curious in the example below:
One session I get 4% Free space. Next session,  or the next,  I get 42% free space. The 4% again.
The pie charts agree each time
Which is the true one? - Or simply 2 versions: Compressed files, and UN compressed files?
If I defrag both versions, am I going around in circles?
    Memory Usage    47 %
    Total Physical    1.49 GB
    Available Physical    806 MB
    Total Virtual    13 GB
    Available Virtual    12 GB
Files compressed to save disc space
Thank you for your patience
Space avail.txt
Share this post
Link to post
the drive in question is only 28GB, so if it's the system drive, the big swings between 4% free and 40% free could easily be because of restore points, pagefile, hibernation file, swapfile, temp files, and the like.
you could either allocate C:\ more space or relocate system files to another drive.
Share this post
Link to post
Could also move particular files such as; Documents, Music, Videos if they're of any significant size onto an external/portable hard disk or SSD to free up space on drive C:\, and also uninstall software that is non-system critical and is no longer being used. 1.2% amount of free space doesn't give Windows much breathing room at all and most defrag tools requires at the bare minimum 10% free space, while other defrag tools may require at least 20% free space - many won't work correctly with only 1.2% free space available.
Share this post
Link to post
Register a new account
Sign in
