jeany70ma Posted March 4, 2019 Share Posted March 4, 2019 Hi I just updated Ccleaner free v5.54.7088. It has downloaded and installed but there is no content in the right side panel. I have re-started my laptop and also installed a second time. Non of this works. I am using an Acer laptop running Windows 10. My husband has same problem running an HP laptop Windows 10. Please see the screenshot encl. Ccleaner screenshot v5.54.7088.docx Link to comment Share on other sites More sharing options...
Moderators Nergal Posted March 4, 2019 Moderators Share Posted March 4, 2019 It looks right to me, what exactly did you expect in that pane? It is where the results will be when you analyize/clean. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
jeany70ma Posted March 4, 2019 Author Share Posted March 4, 2019 Thank you Nergal. I could not see the Analyze and Run Cleaner buttons that are usually displayed when the screen is minimised. It usually opens up after updating as a minimised screen. However it opened up Maximised to such an extent that the buttons were way off the screen, even when I click on minimise it fills the screen but that's OK as I can now see the buttons on the right hand side. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted March 5, 2019 Moderators Share Posted March 5, 2019 The screen size may be because of this mentioned here https://forum.piriform.com/topic/53506-just-installed-5547088-and-it-takes-up-half-my-screen-with-no-way-to-resize/ Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
jeany70ma Posted March 5, 2019 Author Share Posted March 5, 2019 Thank you Hazelnut Link to comment Share on other sites More sharing options...
