Sleve Posted October 28, 2018 Share Posted October 28, 2018 BUG: 2 different HDD's on the same PC show the EXACT same SMART values. One is internal hdd, the other an external usb hdd. One is Seagate ST3250410AS and the other is Seagate FA GoFlex Desk USB Device. Both are 3.5 inch drives. Running Windows 10 Home, fresh install, full updates. Speccy v1.32.740 Link to comment Share on other sites More sharing options...
Moderators Nergal Posted October 28, 2018 Moderators Share Posted October 28, 2018 Moved to speccy bug reporting ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
