Slim Posted September 13, 2018 Share Posted September 13, 2018 Currently on 5.46.6652 and I have had the issue of loading with windows for several ver. now. I am tempted to revert back to an older ver. to avoid this. However, I really don't reboot my machine that much so it's just a minor thing for me, yet very irritating. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted September 13, 2018 Moderators Share Posted September 13, 2018 @Slim i've made you a new thread as this topic is concerning a different issue. In your own thread your problems can be better served. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators Nergal Posted September 13, 2018 Moderators Share Posted September 13, 2018 Can you describe better "loading with windows for several ver. " ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Slim Posted September 13, 2018 Author Share Posted September 13, 2018 @Nergal Thanks. The option in the image attached for "Run CCleaner when the computer starts", having it un-checked doesn't prevent this from happening. Thanks, Slim Link to comment Share on other sites More sharing options...
Moderators Nergal Posted September 13, 2018 Moderators Share Posted September 13, 2018 That setting actually means run cleaning at start-up. Is it cleaning or just starting at boot? If the latter, then make sure on 5.46 that smart cleaning (was monitoring) is turned off. This may fix your ccleaner starting with windows ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Slim Posted September 14, 2018 Author Share Posted September 14, 2018 4 hours ago, Nergal said: That setting actually means run cleaning at start-up. Is it cleaning or just starting at boot? If the latter, then make sure on 5.46 that smart cleaning (was monitoring) is turned off. This may fix your ccleaner starting with windows Thanks, this was my issue and I am grateful you were able to assist me. Slim Link to comment Share on other sites More sharing options...
