Mal007 Posted September 2, 2018 Share Posted September 2, 2018 I have reinstalled 5.46 twice with the same result. (Doesn't empty recycle bin from "run ccleaner" in context menu. Each time I have reverted to 5.41 which, as far as I can see, works correctly. Running Windows 10 Pro 1803 with all updates. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted September 2, 2018 Moderators Share Posted September 2, 2018 The developers are aware on the context menu issues; I believe that they are working on a fix for next release, but have no proof of this. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Guest Ben CCleaner Posted September 10, 2018 Share Posted September 10, 2018 Please see the latest Beta release which should fix this issue Link to comment Share on other sites More sharing options...
