Daniel Ng Posted August 11, 2018 Share Posted August 11, 2018 On startup this morning, a popup message said that CCleaner is not available for use in my location. What changed since yesterday? Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted August 11, 2018 Moderators Share Posted August 11, 2018 There are several problems with build 5.45 and your problem is one of them Piriform has removed the download from their sites and recommend you go back to the previous build 5.44 which can be downloaded here https://www.ccleaner.com/ccleaner/builds or here https://www.ccleaner.com/ccleaner/download Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
LaciBacsi Posted August 14, 2018 Share Posted August 14, 2018 Quote Disable all monitoring options, select the option to "Save all settings to ini file" under Advanced" tab, reboot PC. It seems to not turn on now even after running CCleaner. If you want to defer rebooting, just launch Task Manager and kill the task. Link to comment Share on other sites More sharing options...
