bardi Posted August 3, 2018 Share Posted August 3, 2018 I just installed CCleaner free version 5.45 today. I disabled Monitoring in Options, but continued to see the C in the System Tray. I then went INTO CCleaner, disabled the Startup item and rebooted. The C did not appear upon reboot. Is there some sort of bug with this? I saw also today that How-to Geek was recommending AGAINST using CCleaner because the monitoring seems to be forced on. I hope this is a temporary glitch and will be fixed soon. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted August 3, 2018 Moderators Share Posted August 3, 2018 See here ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
