Tom H Posted July 29, 2018 Share Posted July 29, 2018 ccleaner closes when minimized to system tray. I tried uninstalling and then re-installing but it still does the same thing. This is new behavior. It used to stay pinned to the system tray at all times. Link to comment Share on other sites More sharing options...
jvidal Posted July 29, 2018 Share Posted July 29, 2018 this happens if you uncheck the option to "show ccleaner in systray". check it and you'll at least have it running in the system tray. it is one of the many bugs in the new ccleaner... Link to comment Share on other sites More sharing options...
awtj Posted July 29, 2018 Share Posted July 29, 2018 2 hours ago, jvidal said: this happens if you uncheck the option to "show ccleaner in systray". check it and you'll at least have it running in the system tray. it is one of the many bugs in the new ccleaner... Hi all! I'm having the same issue. I did not uncheck anything, it just started all by itself. I can not find "show ccleaner in systray" anywhere in CCleaner. Any help / ideas appreciated. Link to comment Share on other sites More sharing options...
Tom H Posted July 30, 2018 Author Share Posted July 30, 2018 ccleaner is no longer running reliably without constant attention. I do not have any boxes that say to show ccleaner in the system tray. Clicking the minimize button closes ccleaner. Link to comment Share on other sites More sharing options...
Seymur Posted July 30, 2018 Share Posted July 30, 2018 Same problem in new version ccleaner. Link to comment Share on other sites More sharing options...
jvidal Posted August 1, 2018 Share Posted August 1, 2018 On 29-07-2018 at 19:10, awtj said: Hi all! I'm having the same issue. I did not uncheck anything, it just started all by itself. I can not find "show ccleaner in systray" anywhere in CCleaner. Any help / ideas appreciated. go to options-->configuration (or settings, mine is in spanish), it's the second checkbox. Link to comment Share on other sites More sharing options...
LikeableRogue Posted May 5, 2020 Share Posted May 5, 2020 (edited) I have used CCleaner for several years. All works well until i purchased a package deal of a ccleaner pro last week and defrag and some other app in the bundle (it was only a few dollars more to get the bundle than just ccleaner pro) . So when i installed the bundle that's when ccleaner disappeared from the system tray. Minimise to tray option is checked but no go. When i installed the bundle you do have the option not to install specific packages in the bundle..i deselected ccleaner as it was already installed and the other app ..i just wanted defragggler. Anyway it updated the license detail of ccleaner with the new bundle license and wont stay in the tray. i uninstalled ccleaner, reinstalled and it picked up the bundle license key and still wont stay in the tray. Another mystery that i will work on one late night Edited May 5, 2020 by LikeableRogue Link to comment Share on other sites More sharing options...
