arcobelina Posted June 30, 2018 Share Posted June 30, 2018 I have windows 10, latest version available form microsoft Home user, version 1803, 17134.12 using reinstalled latest version of CCleaner. 544.162.6575 I re-installed because when I click to start Ccleaner and press "run ccleaner" it stops. It disappears from the task manager. I have scanned for viruses, restarted the PC and can't get Ccleaner to work. Problem began 12 hours ago, I have slept since then. Link to comment Share on other sites More sharing options...
Bastet Posted June 30, 2018 Share Posted June 30, 2018 Do you have MalwareBytes premium installed or a trial of the same? One of the settings seems to have an adverse affect on several programs including CCleaner. Virginia/Bastet. Windows 11 Pro 22H2. CCleaner Pro. MalwareBytes Pro. Defender. Macrium Reflect Home. Link to comment Share on other sites More sharing options...
arcobelina Posted June 30, 2018 Author Share Posted June 30, 2018 I dont have malwarebytes. I have changed nothing on my system, I dont think there has been an auto update of Windows this week. 24 hours ago it worked fine. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted June 30, 2018 Moderators Share Posted June 30, 2018 14 minutes ago, arcobelina said: I dont have malwarebytes. I have changed nothing on my system, I dont think there has been an auto update of Windows this week. 24 hours ago it worked fine. What antivirus are you running then ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
arcobelina Posted June 30, 2018 Author Share Posted June 30, 2018 I use Kaspersky anti virus. I have lodged a support ticket with them to see if they have blocked Ccleaner to try and push people towards their cleaner. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted July 1, 2018 Moderators Share Posted July 1, 2018 See the linked comments in this ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
arcobelina Posted July 1, 2018 Author Share Posted July 1, 2018 Thank you Nergal. fixed it goodonya Link to comment Share on other sites More sharing options...
