Job4848 Posted May 28, 2018 Share Posted May 28, 2018 Windows 10 Pro x64, CCleaner v5.43.6522 64-bit. Have been a CCleaner Pro user for years. Have it set to load at Windows Boot. For a period of time after a large patch from Microsoft, I want to keep the backup files in case I need to back off an update. I AM TICKED OFF. I didn't catch it in time, and it cleaned some percentage before I noticed. EVERY TIME I reboot the computer, it does the same thing. It starts an automatic clean. I NEVER WANT IT TO AUTOMATICALLY KICK OFF A CLEAN. I ALWAYS look through cookies, for example, before running a clean. Been away from the computer for 3 weeks. Come back and so ended up there were 2 big updates. Now since this malfunction, I can only assume that I can no longer back out of the upgrade, which I am having issues with. At one point, it said it could save 13 gig of space. Running an analysis now shows 8 gig to be removed - I have lost 5 gig so far due to this malfunction. Oddly, when I open CCleaner after boot, it does not take off and run without my permission. Options, Monitoring, I have enabled system monitoring, and set If cleaning saves more than..... 15GB. It STILL autocleans. I want it to notify me when there is a need for a clean. I don't want a nag every 5 minutes. There should be an option to adjust how frequently it reminds you again that you need a clean. Link to comment Share on other sites More sharing options...
