jstab Posted April 26, 2018 Share Posted April 26, 2018 Just installed V5.42.6495 64bit (free). The Cleaner portion does not work. After analyzing, choosing "Run Cleaner" and then 'continue' exits the program without 'cleaning'. The Registry cleaner works perfectly. Hope there is a fix. Link to comment Share on other sites More sharing options...
nolan_vode Posted April 27, 2018 Share Posted April 27, 2018 I don't know about using the installer, but I use the portable version, and it works normally. No problems. Link to comment Share on other sites More sharing options...
Diazruanova_1 Posted April 27, 2018 Share Posted April 27, 2018 21 hours ago, jstab said: Just installed V5.42.6495 64bit (free). The Cleaner portion does not work. After analyzing, choosing "Run Cleaner" and then 'continue' exits the program without 'cleaning'. The Registry cleaner works perfectly. Hope there is a fix. Exact same behavior, so I had to revert to CCleaner Ver. 5.41.6446 and it works fine. Link to comment Share on other sites More sharing options...
Paul_8ain Posted April 28, 2018 Share Posted April 28, 2018 Installed 5.42, and the Cleaner function crashed immediately. All previous vesions up to 5.41 were fine. Perhaps someone could try testing this before it gets released? Other functions (Uninstall, Registry Cleaner) were OK. Link to comment Share on other sites More sharing options...
