ldeveraux Posted May 16, 2018 Share Posted May 16, 2018 The new version released today On 4/16/2018 at 05:35, Stephen Piriform said: Hey guys, This is basically what we're working on for the May release. You'll have the option to default your cleaning results to one of three options: Simple (the simplified 'Cleaning Summary') Advanced (as it used to be by default) Complete (full list of files) So I installed the May release today and this function wasn't changed back. Will it be in the future? Link to comment Share on other sites More sharing options...
MWexe Posted May 16, 2018 Share Posted May 16, 2018 8 hours ago, Kiwi said: How to skip this window? I can't find any option. I just downloaded the latest version but it still shows this annoying window. Yes.. annoying isn't it! For now, until the promised Advanced Report options are 'soon' instigated (I was also really expecting it in this May release too!): Go to 'Options'-->'Advanced' where you can tick the 'Show Cleaner results as a file list' box. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted May 16, 2018 Moderators Share Posted May 16, 2018 42 minutes ago, ldeveraux said: The new version released today So I installed the May release today and this function wasn't changed back. Will it be in the future? Today's release was a hotfix for the chrome corruption. The release has slightly delayed the next iteration of ccleaner. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
Admin Stephen CCleaner Posted May 17, 2018 Admin Share Posted May 17, 2018 The v5.42 hotfix was released ahead of the v5.43 release because we felt that an urgent fix was needed for some users who were losing their Chrome preferences after a clean. I have explained the specifics of this bug in this post. The v5.43 release, which contains the setting for the Cleaning Results, has been delayed for a few reasons: Our testers needed to focus on the critical hotfix released mentioned above. The Windows 10 April Release (build 1803) contains a very nasty bug that can prevent Windows 10 from booting after the Font Cache is cleaned. While this cleaning rule is not enabled by default, we do believe that the severity of the issue is strong enough that we should delay the v5.43 release to add a temporary fix to prevent our users from encountering this issue. The Windows 10 April Release has resulted in compatibility issues with many software products, so we are spending some extra time to test it. v5.43 is in final testing and will not be too much longer. Link to comment Share on other sites More sharing options...
ldeveraux Posted May 17, 2018 Share Posted May 17, 2018 48 minutes ago, Stephen Piriform said: The v5.42 hotfix was released ahead of the v5.43 release because we felt that an urgent fix was needed for some users who were losing their Chrome preferences after a clean. I have explained the specifics of this bug in this post. The v5.43 release, which contains the setting for the Cleaning Results, has been delayed for a few reasons: Our testers needed to focus on the critical hotfix released mentioned above. The Windows 10 April Release (build 1803) contains a very nasty bug that can prevent Windows 10 from booting after the Font Cache is cleaned. While this cleaning rule is not enabled by default, we do believe that the severity of the issue is strong enough that we should delay the v5.43 release to add a temporary fix to prevent our users from encountering this issue. The Windows 10 April Release has resulted in compatibility issues with many software products, so we are spending some extra time to test it. v5.43 is in final testing and will not be too much longer. Great, thanks for the update! Link to comment Share on other sites More sharing options...
MWexe Posted May 17, 2018 Share Posted May 17, 2018 Thanks for the heads-up there Stephen.. and good luck. Standing by.. Link to comment Share on other sites More sharing options...
jaddorf Posted May 17, 2018 Author Share Posted May 17, 2018 Wow - imagine when you guys change a major feature! The blowback.... Link to comment Share on other sites More sharing options...
Kiwi Posted May 17, 2018 Share Posted May 17, 2018 On 16.5.2018 at 18:24, nukecad said: Have you actually read the above posts? There is a change promissed for the next update which will let you pick which screen you see. Yes it said it will come with the may release. I downloaded the version which was released in may and still didn't see any way to skip this message thats why I posted here. 8 hours ago, Stephen Piriform said: The v5.42 hotfix was released ahead of the v5.43 release because we felt that an urgent fix was needed for some users who were losing their Chrome preferences after a clean. I have explained the specifics of this bug in this post. The v5.43 release, which contains the setting for the Cleaning Results, has been delayed for a few reasons: Our testers needed to focus on the critical hotfix released mentioned above. The Windows 10 April Release (build 1803) contains a very nasty bug that can prevent Windows 10 from booting after the Font Cache is cleaned. While this cleaning rule is not enabled by default, we do believe that the severity of the issue is strong enough that we should delay the v5.43 release to add a temporary fix to prevent our users from encountering this issue. The Windows 10 April Release has resulted in compatibility issues with many software products, so we are spending some extra time to test it. v5.43 is in final testing and will not be too much longer. Thanks for posting usefull information instead of bulls**t. Link to comment Share on other sites More sharing options...
ldeveraux Posted May 18, 2018 Share Posted May 18, 2018 18 hours ago, Kiwi said: Yes it said it will come with the may release. I downloaded the version which was released in may and still didn't see any way to skip this message thats why I posted here. Thanks for posting usefull information instead of bulls**t. Grow up Kiwi. Link to comment Share on other sites More sharing options...
Kiwi Posted May 18, 2018 Share Posted May 18, 2018 1 hour ago, ldeveraux said: Grow up Kiwi. What your problem? Go and annoy someone else with your useless post! Link to comment Share on other sites More sharing options...
Moderators Augeas Posted May 18, 2018 Moderators Share Posted May 18, 2018 That's enough squabbling, thanks. Link to comment Share on other sites More sharing options...
ldeveraux Posted May 19, 2018 Share Posted May 19, 2018 Thanks for "warning" me! Really makes me confident that your priorities are in order! Link to comment Share on other sites More sharing options...
Moderators mta Posted May 19, 2018 Moderators Share Posted May 19, 2018 Moderator priorities are to keep the forum and its members in order. Your priorities are to discuss matters in a civil manner as per forum rules - something you still aren't grasping. Backup now & backup often.It's your digital life - protect it with a backup.Three things are certain; Birth, Death and loss of data. You control the last. Link to comment Share on other sites More sharing options...
ldeveraux Posted May 19, 2018 Share Posted May 19, 2018 11 minutes ago, mta said: Moderator priorities are to keep the forum and its members in order. Your priorities are to discuss matters in a civil manner as per forum rules - something you still aren't grasping. You know what buddy, you can jog on. I came here to check if an issue had been fixed and it hadn't. Some clown started mouthing off, using foul language, I simply asked him to grow up. For some reason you need to pump your ego by extending your authority. If this is what you do in down time to cover up the fact that software issues and user complaints aren't being addressed, that's a Piriform problem. You can warn me, ban me, do what you must to prevent me from daring to ask someone to grow up. I hope it makes you warm and fuzzy to pick on the little guy. Link to comment Share on other sites More sharing options...
Moderators mta Posted May 20, 2018 Moderators Share Posted May 20, 2018 Admins already aware of OP's issue - tick Newbie insults member - tick warn user - tick Newbie re-offends - tick Newbie banned - tick feeling warm and fuzzy - tick Backup now & backup often.It's your digital life - protect it with a backup.Three things are certain; Birth, Death and loss of data. You control the last. Link to comment Share on other sites More sharing options...
trium Posted May 23, 2018 Share Posted May 23, 2018 Quote - Added preference to select the level of detail on the Cleaning Results screen Quote options -> advanced -> cleaning results level of detail: -> advanced report thanks for the good old cleaning results back to us Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
MWexe Posted May 25, 2018 Share Posted May 25, 2018 Yes - a +1 on that effort/response. Thank you! Unfortunately I am stuck with a Win 10 1803 Installation refusal and had to resort to the "Portable" workaround for CC. 4.52. Will you later offer 4.53 and/or newer as a Portable build too please? This will be a big help! Later Edit.. Thanks for the (latest) Portable Versions Update too. Link to comment Share on other sites More sharing options...
