skiggy Posted January 17, 2018 Share Posted January 17, 2018 Hi, for some months now and through several different iterations of CCleaner I have had a problem. When I open CCleaner initialy, everything appears except the checkbox items, also CCleaner renders itself unusable by using the hourglass so nothing can be opened. This continues for between 1 to 2.5 minutes then the checkboxes appear along with the normal curser and everything is as normal. is it my PC or CCleaner? Link to comment Share on other sites More sharing options...
Moderators Nergal Posted January 18, 2018 Moderators Share Posted January 18, 2018 Are you using a winapp2.ini or any ccleaner enhancing addons? ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
