Moderators Andavari Posted April 10, 2018 Moderators Share Posted April 10, 2018 2. However it would be multiple files and folders. I realize allot of shell extensions, or even drag 'n' drop secure delete programs can have issues working correctly 100% of the time as in sometimes a file is shredded correctly but the shredded file is left on the disk and not deleted from view. Link to comment Share on other sites More sharing options...
ident Posted April 13, 2018 Share Posted April 13, 2018 what is the issue? if you want it to apply to all files, you have to add a hive to HKEY CLASSES ROOT/* which is basic enough. EX: HKEY_CLASSES_ROOT\123\shell\******** HKEY_CLASSES_ROOT\123\shell\********\command @=C:\Program Files\********folder\********.EXE %1 This was an unfinished test mock(15 years ago or just under i think) i used that allowed a user to download CCleaner, install & uninstall context menus and upload multiple files to image shack. Imports DX Imports Rhino.Mocks Imports Rhino.Mocks.Constraints Imports Xunit Imports Xunit.Extensions ' Tests the ShellContextMenuProcess class. Public Class TestShellContextMenuProcess <Fact()> _ Public Sub SetProcessManager_ProcessManagerIsNull_Throws() Dim expectedExceptionType As Type = GetType(ArgumentNullException) Dim exceptionWasThrown As Boolean Try Dim sut As New ShellContextMenuProcess() sut.SetProcessManager(Nothing) Catch ex As Exception exceptionWasThrown = True Assert.IsType(expectedExceptionType, ex) End Try Assert.True(exceptionWasThrown, "Exception was not thrown.") End Sub <Fact()> _ Public Sub StartInstall_Invariant_UsesRegisterArgument() Dim sut As New ShellContextMenuProcess() Dim expectedMode As String = "register" Dim processManagerMock As ProcessManager = New ProcessManagerMockThatExpectsModeArgument(expectedMode) sut.SetProcessManager(processManagerMock) sut.Install() CType(processManagerMock, ProcessManagerMockThatExpectsModeArgument).Verify() End Sub <Fact()> _ Public Sub StartUninstall_Invariant_UsesUnregisterArgument() Dim sut As New ShellContextMenuProcess() Dim expectedMode As String = "unregister" Dim processManagerMock As ProcessManager = New ProcessManagerMockThatExpectsModeArgument(expectedMode) sut.SetProcessManager(processManagerMock) sut.Uninstall() CType(processManagerMock, ProcessManagerMockThatExpectsModeArgument).Verify() End Sub <Fact()> _ Public Sub WaitForExit_Success_ReturnsTrue() Dim expectedValue As Boolean = True Dim sut As New ShellContextMenuProcess() Dim processManagerStub As ProcessManager = New ProcessManagerStubThatReturnsSpecificExitCode(ShellContextMenuProcess.SuccessCode) sut.SetProcessManager(processManagerStub) Dim actualValue As Boolean = sut.Install() Assert.Equal(expectedValue, actualValue) End Sub <Fact()> _ Public Sub WaitForExit_Failure_ReturnsFalse() Dim expectedValue As Boolean = False Dim sut As New ShellContextMenuProcess() Dim processManagerStub As ProcessManager = New ProcessManagerStubThatReturnsSpecificExitCode(ShellContextMenuProcess.FailureCode) sut.SetProcessManager(processManagerStub) Dim actualValue As Boolean = sut.Install() Assert.Equal(expectedValue, actualValue) End Sub ' Handwritten mock that tests that the Arguments property is set and it has the expected mode. Private Class ProcessManagerMockThatExpectsModeArgument Inherits ProcessManager Private Const ExpectedNumberOfArguments As Integer = 2 Private _expectedMode As String Private _propertyWasSet As Boolean Public Sub New(ByVal expectedMode As String) MyBase.New("asdf") _expectedMode = expectedMode _propertyWasSet = False End Sub Public Overrides Property Arguments() As String() Get Return MyBase.Arguments End Get Set(ByVal value As String()) Assert.Equal(ExpectedNumberOfArguments, value.Length) Assert.Equal(_expectedMode, value(1)) MyBase.Arguments = value _propertyWasSet = True End Set End Property Public Sub Verify() Assert.True(_propertyWasSet, "Arguments was not set.") End Sub ' Always returns success Protected Overrides Function GetExitCodeCore() As Integer Return ShellContextMenuProcess.SuccessCode End Function Protected Overrides Sub StartProcess() ' Do nothing, we don't need to start a process for tests. End Sub Protected Overrides Sub WaitForExitCore() ' Do nothing. End Sub End Class ' ProcessManager stub that returns a desired exit code and has no other logic. Public Class ProcessManagerStubThatReturnsSpecificExitCode Inherits ProcessManager Private _exitCode As Integer Public Sub New(ByVal exitCode As Integer) MyBase.New("asdf") _exitCode = exitCode End Sub Protected Overrides Function GetExitCodeCore() As Integer Return _exitCode End Function Protected Overrides Sub StartProcess() ' Do nothing. End Sub Protected Overrides Sub WaitForExitCore() ' Do nothing End Sub End Class End Class Imports DX Imports Xunit Imports Xunit.Extensions Imports Rhino.Mocks ' Tests the ShellContextMenuInstaller class. Public Class TestShellContextMenuInstaller <Fact()> _ Public Sub Install_Failure_ReturnsFalse() Dim expectedValue As Boolean = False Dim sut As New ShellContextMenuInstaller() Dim processStub As ShellContextMenuProcess = New ShellContextMenuProcessStub_ReturnsSpecificValue_FromGetWaitForExit(expectedValue) sut.SetProcess(processStub) Dim actualValue As Boolean = sut.Install() Assert.Equal(expectedValue, actualValue) End Sub <Fact()> _ Public Sub Install_Success_ReturnsTrue() Dim expectedValue As Boolean = True Dim sut As New ShellContextMenuInstaller() Dim processStub As ShellContextMenuProcess = New ShellContextMenuProcessStub_ReturnsSpecificValue_FromGetWaitForExit(expectedValue) sut.SetProcess(processStub) Dim actualValue As Boolean = sut.Install() Assert.Equal(expectedValue, actualValue) End Sub <Fact()> _ Public Sub Uninstall_Failure_ReturnsFalse() Dim expectedValue As Boolean = False Dim sut As New ShellContextMenuInstaller() Dim processStub As ShellContextMenuProcess = New ShellContextMenuProcessStub_ReturnsSpecificValue_FromGetWaitForExit(expectedValue) sut.SetProcess(processStub) Dim actualValue As Boolean = sut.Uninstall() Assert.Equal(expectedValue, actualValue) End Sub <Fact()> _ Public Sub Uninstall_Success_ReturnsTrue() Dim expectedValue As Boolean = True Dim sut As New ShellContextMenuInstaller() Dim processStub As ShellContextMenuProcess = New ShellContextMenuProcessStub_ReturnsSpecificValue_FromGetWaitForExit(expectedValue) sut.SetProcess(processStub) Dim actualValue As Boolean = sut.Uninstall() Assert.Equal(expectedValue, actualValue) End Sub Private Class ShellContextMenuProcessStub_ReturnsSpecificValue_FromGetWaitForExit Inherits ShellContextMenuProcess Private _expectedValue As Boolean Public Sub New(ByVal expectedValue As Boolean) MyBase.New() _expectedValue = expectedValue Dim mocks As New MockRepository() SetProcessManager(mocks.Stub(Of ProcessManager)("asdf")) End Sub Public Overrides Function GetTargetPath() As String Return "" End Function Protected Overrides Function WaitForExit() As Boolean Return _expectedValue End Function End Class End Class Passing a List(of Q off to a task factory, for instance, is nothing to you guys. Whats the issue? I understand each new file would be sent to a new instance, so this leaves us with a couple options I know which ain't pretty like me 1) SEND TO PATH: Nasty ain't it. No commands would be needed but.....yes let's move on from that one. 2) could CC work with MultiSelectModel verb..... Too tired to look into this but it's how video plays work. I think. 3) let me write the class for you in VB.Net http://www.vbforums.com/member.php?113656-ident No fate but what we make Link to comment Share on other sites More sharing options...
Moderators Andavari Posted April 13, 2018 Moderators Share Posted April 13, 2018 Why are you posting all that code? It makes little sense to do so! Link to comment Share on other sites More sharing options...
