New_Age Posted May 2, 2006 Share Posted May 2, 2006 Hi, Me again. Ok, I'm still networked on the "Netgear MR814V.2 Wireless/Cable/DSL/4-port Router". One computer upstairs and two are downstairs. One is connected to one port in the router and the others our Wireless. Wireless Adpaters are "D-Link 's DWL-G510". I'm having problems on "Myspace" and that's including any... profile and I'm also having connection drops on other websites as well. I've resetted the ADSL Modem and the Router. I put in the CD and started it up and re-put everything in. The log-in, Account Info. and what not. The connection is still slow. What could be causing this Issues? I don't feel like calling our ISP Link: Modem - http://www.zyxel.com/web/product_family_de...6A-CAB0FC58490F Link: Router - http://kbserver.netgear.com/products/MR814v2.asp Software Included with CD: Total Access 2005* Note: No Spyware or Viruses on computers. CLEAN! Windows 7 Ultimate 64-Bit Edition | COOLER MASTER Centurion 590 with 4 120mm Blue LED FANS 1 Regular 120MM FAN and a Custom Window Side Panel | AMD Athlon II x4 2.6GHZ Stock| XIGMATEK HDT-S963 92mm | ASRock A780GXE/128 | G.SKILL 4GB (2 x 2GB) @800MHZ | CF 2 XFX 4850 1GB @GPU940/MEM1005 | 320GB/OS 160GB/Storage HDDs | LG CD/DVD SATA | Rosewill 600W 2 12v Rail@44 | Ccleaner, Defraggler | Malwarebytes', SUPERAnti-Spyware | Avira AntiVir Personal | Google Chrome v3/4, IE8 Link to comment Share on other sites More sharing options...
krit86lr Posted May 3, 2006 Share Posted May 3, 2006 I have been having the same problem. MSN has been having problems with their site for 2 weeks now. In my case it isn't my network so it might not be yours either. Hope this helps. Windows Pro Media 8.1 x64 | 8GB Ram | 500G HDD 7200 RPM | All that I know about my graphics is that it's Intel Link to comment Share on other sites More sharing options...
Glenn Posted May 4, 2006 Share Posted May 4, 2006 Have you clocked your connection speed against a test site? Any difference in performance if you use the one wired computer versus one wireless versus all three at the same time? Link to comment Share on other sites More sharing options...
oli Posted May 4, 2006 Share Posted May 4, 2006 you could try upgrading the firmware, i did that and adsl stability gpt better Homer: I never apologise, im sorry Lisa. Thats just the way i am Link to comment Share on other sites More sharing options...
zaphirer Posted May 5, 2006 Share Posted May 5, 2006 One thing that can dramatically increase performance is turning off encryption. Then you can limit the router to certain MAC addresses to prevent anyone from connecting. Link to comment Share on other sites More sharing options...
