Moderators hazelnut 5 Posted January 6, 2018 Moderators Share Posted January 6, 2018 Check your HP battery from list. Also a bios update is offered to disable the battery (must be bad) https://www.bleepingcomputer.com/news/hardware/hp-recalls-laptop-batteries-due-to-overheating-and-fire-hazard/ Link to post Share on other sites
mithras123 0 Posted January 30, 2018 Share Posted January 30, 2018 i don't have any problem with my hp batery but I have with my charger. do you recommend to buy one new or to repair it? Link to post Share on other sites
Moderators nukecad 7 Posted February 11, 2019 Moderators Share Posted February 11, 2019 Download the application to check if your particular battery is affected, the recall programme has been expanded so run the new checking application which you can find on this webpage:https://batteryprogram687.ext.hp.com/ Also take a look at the FAQ's there. If it is affected then there are contact phone numbers and email details on that webpage. If you have a non-user replaceble battery which is affected you should also update your BIOS to diable the internal battery until it can be replaced. Quote Many of these batteries are internal to the system, which means they are not customer replaceable. HP is providing battery replacement services by an authorized technician at no cost. HP is also releasing an update to the BIOS to add batteries affected by the program expansion. The updated BIOS places the battery in "Battery Safety Mode" so that the notebook or workstation can be safely used without the battery by connecting to an HP power adaptor. Batteries affected by this recall should immediately be put into "Battery Safety Mode". Link to post Share on other sites
