missminerva Posted April 28, 2017 Share Posted April 28, 2017 Anyone know why this would be there? It shows mine, as it should, and then shows my upstairs neighbor as well. Do I need to be concerned about this? Thanks much for any help! Wi-Fi (ME) SSID ME Frequency 2412000 kHz Channel Number 1 Name ME Signal Strength/Quality 100 Security Enabled State The interface is connected to a network Dot11 Type Infrastructure BSS network Network Connectible Network Flags Currently Connected to this network Cipher Algorithm to be used when joining this network AES-CCMP algorithm Default Auth used to join this network for the first time 802.11i RSNA algorithm that uses PSKWi-Fi (Minckstir) NEIGHBOR SSID Minckstir Frequency 2447000 kHz Channel Number 8 Name Minckstir Signal Strength/Quality 82 Security Enabled State The interface is connected to a network Dot11 Type Infrastructure BSS network Network Connectible Network Flags There is a profile for this network Cipher Algorithm to be used when joining this network AES-CCMP algorithm Default Auth used to join this network for the first time 802.11i RSNA algorithm that uses PSK Link to comment Share on other sites More sharing options...
craigathus Posted April 29, 2017 Share Posted April 29, 2017 Hi missminerva With speccy I can see my neighbors wifi info as well' and can also see their network in the list of available networks to join via Windows "Network and Sharing Center"> if I had their password I assume that they can see my info too. Keep your network security enabled ! And make sure a password is needed to join your network ! http://www.piriform.com/ccleaner/builds http://www.piriform.com/docs http://www.postimage.org/ Link to comment Share on other sites More sharing options...
missminerva Posted April 29, 2017 Author Share Posted April 29, 2017 Thanks much! Never noticed it before. Pretty sure I'm covered... Link to comment Share on other sites More sharing options...
Moderators nukecad Posted April 29, 2017 Moderators Share Posted April 29, 2017 It will show any wifi network that your PC / laptop is currently picking up. At the moment my laptop is showing mine plus three others, and all also show in speccy. (All neighbours, and I do have the passwords for two of them). If you have unlimited broadband it's can be a good idea to share passwords with a trusted neighbour who also has unlimited. Then if something happens to yours you can use theirs while you sort it out, and vice-versa. *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
