How to undo a Quick Format
richd
I accidentally did a Quick Format on my WD 1TB Passport external USB drive.
I believe that the MFT (master file table) must still be there since I was able to see lots (but not all) files when I did a Scan with Recuva.
Unfortunately, I only see about half of my file and folder set.
When I did a recover to a separate Seagate 4 TB external drive, they WERE (good news) placed in a folder structure like I hd them.
QUESTIONS:
1. How can I put the MFT back in place in the WD drive so that I get all files on that WD drive available?
2. Do I need to do something special?
3. As a feature of Recuva, shouldn't there be an UNDO capability as I see that a lot of people online do this?
Link to comment
  • Moderators
Link to comment
Guest
This topic is now closed to further replies.
Important Information
