CCleaner Community Forums
Grimdal
v5.27.5976 (64Bit) - downloads installs - but crashes when running
downloaded and installed this morning, it starts up ok, Analysis ok, starts running clean up then crashes, without giving a decent error message, screen shot attached
Share this post
Link to post
just to see if it helps, tell CC not to clean Chrome and see if it completes.
try cleaning Chrome from within Chrome as a one off, then try CC again.
is still no luck, run CC with the /debug switch and attach the output.
Share this post
Link to post
unticked the Chrome cleanup - Still failed this time while doing Firefox - reran with /debug files attached
had to change the extention on both files to get it to allow the upload
CCLeaner64.exe.4808.dmp
CCleaner64_v5.27.5976_2017-02-16_11-16.log
let me know if you need any other files or info
CCleaner64.exe.4808.txt
CCleaner64_v5.27.5976_2017-02-16_11-16-41.txt
Share this post
Link to post
Zip the files first and then  upload them, that way you won't need to change the extension.
Share this post
Link to post
thanks for that @Grimdal, now the Devs will have more info to hopefully investigate further.
you aren't the only one this is happening to.
Share this post
Link to post
Same problem v5.27(Pro)  (Win 10 Home) I use the program for more than 2 years on the same PC, the first time that something like this.
Share this post
Link to post
Adding my name to  this growing list. Installed the latest update yesterday.  Ccleaner analyzes fine, but when cleaning around 92% and up it crashes.  I am running Win 10 home 64-bit.
Share this post
Link to post
To the three "me too" posters please provide a debug report. Instructions are in a sticky topic at the top of the ccleaner's bug report board.
Share this post
Link to post
Here is the log file from running ccleaner in debug mode.
Try turning off firefox - compact databases, see if it still crashes.
Share this post
Link to post
Ok Nergal I did that and ccleaner worked just fine.  Under firefox, I unticked compact database and it worked like it always has.  I noticed that Chrome has that same feature also. I would imagine if you untick compact databases under chrome it will work just fine like mine did.
Share this post
Link to post
I've reported to the developers, that compact is causing crashes
Share this post
Link to post
Since the new version was installed, I am also having trouble. CCeaner is installing completely, but crashes when it is running the Clean. I've read thru the posts here and have tried everything except doing a Window 10 recovery to an earlier date.
UPDATE: I don't use Google Chrome, but I have it installed. When I turned off the Chrome CCclean, no changes... the program still crashed. Then, with Chrome off, I turned off Firefox. CClean finished the scan... ok.... then I started with Firefox and started rechecking ONE box ant a time instead of all under the Firefox tab.... CClean continued to run perfectly until I checked and ran with "Internet History"  or with "Internet Cache" checked. Then CClean failed until I turned off the "Internet History" or the "Internet Cache" checkbox(s)... hope that helps you guys.
Share this post
Link to post
Ok, i am also using windows 7, if i put back in Firefox and Chrome, but leave "Compact Databases" unticked, CCleaner works, so definately in the right area
Share this post
Link to post
Been using for a long time on XP. New version gets stuck at 25% while cleaning recycle bin and never finishes. Tried unchecking cache and history boxes on firefox, no difference. Tried uninstall and redownloaded, no change. I'm not a techie so I'm not going crazy to try and make this work. I like the product but if it doesn't work I'll try something else.
Share this post
Link to post
likely a different issue. With XP it might mean your recycle bin is corrupted
Follow the xp link from
https://forum.piriform.com/index.php?showtopic=42673&do=findComment&comment=257977
Share this post
Link to post
... been running CCleaner without problems for years on my six rigs ... but
after updating to v5.27.5976(64-bit) CCleaner crashes at around 97% (Firefox) on only ONE of my PCs.
All PCs have Win7 Pro 64-bit running - each with two accounts (one admin and one normal user).
CCleaner works OK with the ADMIN account (on the one and only crashing system), but crashes when executing it on the second (normal user) account.
After reading the post here, I unchecked the "compact database" option for Firefox and it then works OK.
I'm not running other browsers (except IE - not using it).
I have attached a zipped dump log file.
The dump instructions you have pinned are not quite correct - the log file is located unser user appdata local crashdumps (at least on my setup).
Have a nice day!
CCleaner64.exe.4688.zip
Share this post
Link to post
... hate to bug you people, but your bug is bugging us ....
Reported problem (see post #19 here), included dump, no reply from your side.
Installed v5.28.6005(64bit) today - still no go ...
We would really appreciate your help/solution!
Have another nice day
Share this post
Link to post
we have been informed by the Admins that a solution for the Compact Database issue will be in the next release. ;)
Share this post
Link to post
v5.26 does not exhibit this issue... rolled it back and works fine.  IMHO it makes no sense to roll-out v5.28 without addressing a show-stopper.
Share this post
Link to post
it's hardly a show-stopper, untick one box and the problem goes away.
it's an annoyance at best.
yes, it was sad it wasn't released with v5.28 but there would have been a reason, most likely a solution wasn't ready in time for the scheduled release.
Share this post
Link to post
dear mta (post #24),
your answer is very unprofessional.
WHY?  Because we need this option (that you point out to untick) on a regular daily basis for "production".
So, please be careful with your simplified sayings.
Have a nice day ...
Share this post
Link to post
Register a new account
Sign in
